Rubber or Plastic like strip assembly - Rear Bumper
Discussion in 'Body Restoration' started by britchris, Nov 18, 2018.
  1. britchris
    britchris Veteran Member
    137
    Apr 26, 2004
    USA
    Peeps,
    Between the Chrome rear bumper and the body is a black rubber urethane like material moulded to fill the gap between the bumper and the body. It is going the way off all flesh and disintegrating. Are the "bumper fill" assemblies available?
    Thanks
  2. Jon balch
    Jon balch Veteran Member Gold Member
    222
    61
    Mar 29, 2017
    Upstate NY
    D070C172-B956-4080-9D27-2A935CF80245.png Camaro central has them
  3. dave@ztech
    3,197
    648
    Mar 27, 2016
    NY
    There is also a member here that sells them,just having a problem remembering the name,
  4. BillyDean7173
    BillyDean7173 Veteran Member
    1,357
    225
    May 21, 2014
    Hutto, TX
    l16pilot sells the 70-72 rear bumper cushions. Great reproductions.
  5. l16pilot
    1,801
    121
    Dec 13, 2004
    Hurlock, MD, USA
    britchris - Not sure what year you're dealing with but there for two different bumper end cushions 70-72 and '73 was a one-year only. The Camaro Central cushions noted above are for the '73. I produce the 70-72 cushions...so it all depends on the year of your car.
  6. britchris
    137
    Apr 26, 2004
    USA
    Thank you folks, it would have helped if I'd added the year. It's a 76 standard model. Attached is a pic of what I'd like to get. Between the bumper and the body sits a black filler assembly. After 42 years this is literally falling apart. I think there is a great cottage industry out there for someone with a 3-D printer to turn out these sorts of parts.
  7. l16pilot
    1,801
    121
    Dec 13, 2004
    Hurlock, MD, USA
    Well, I think calling the bumpers chrome threw us all off. Yours are clear anodized aluminum. Good luck on your search, no clue of a source for the fillers you need.
  8. BonzoHansen
    19,245
    679
    Jun 1, 2005
    Scott from Hamilton, NJ
  9. britchris
    137
    Apr 26, 2004
    USA
    Got it thanks!
  10. 75Maro
    75Maro Veteran Member
    408
    17
    Mar 31, 2008
    Dallas,Tx
    I have a set for sale. Check the swap meet section
