Rust prevention
Discussion in 'Tips 'n' Tricks Topic' started by Kskevin, Feb 8, 2019.
  1. Kskevin
    Kskevin Member
    42
    Feb 6, 2019
    Was wondering if you guys have any tips on keeping the block from rusting while doing a rebuild. I live in Kansas and temps fluctuate quite a bit and it will be in my garage. I've herd wd-40 or ATF just wanted your guys thoughts.
  2. perkalator
    perkalator Veteran Member
    1,025
    89
    Aug 27, 2014
    kennewick wa
    spray everything down with wd40, wipe it in and coat again. Then cover the engine with a large garbage bag. You may want to re-coat with wd40 every couple weeks depending on the environment of your storage area.
  3. Kskevin
    Kskevin Member
    42
    Feb 6, 2019
    Thanks for the reply will definitely do it every two weeks the temp fluctuates slot here and high humidity normally.
  4. Kskevin
    Kskevin Member
    42
    Feb 6, 2019
  5. badazz81z28
    16,723
    465
    Las Vegas, NV
    LPS3 if it’s for storage. During the process, I oiled up the block routinely. If your going to use WD 40, look into their gel formulas. It will stick longer
  6. CorkyE
    10,310
    450
  7. 8pack
    2,619
    149
    Aug 29, 2007
    Western, MA
    Gibbs oil. Blows away WD-40. you can also paint over it and don't have to worry about it when you paint the block later. Fluid film is Lanolin and is great but leaves a lot of residue. I use it on a lot of undercarriage stuff....
    http://www.gibbsbrandlubricant.com/
    Google it, you will see a lot of good info and first hand users....
