Rust scale removal tool?
Discussion in 'Body Restoration' started by Mitch'80Z, Sep 6, 2015.
  1. Mitch'80Z
    Mitch'80Z Veteran Member
    1,336
    Sep 20, 2001
    Northeast Ohio
    I am going to clean up my hauling trailer's frame. For the light rust scaling it has, a 3M rust/paint stripping disk seems to work just fine and gets into the inside angles well. I'll finish up with a rust converter for any pits and then topcoat with a bedliner-type paint.
    All I have is a cordless drill to run the disks and the batteries just can't keep up with me. I need to buy something else.
    My question is this, should I buy a 3/8" corded power drill or a die-grinder? I have a Craftsman 4hp 15gal compressor to run the grinder. The compressor has 8.9 scfm@40 psi and 6.9 scfm @90 psi. (I thought about a media blaster but don't want the mess).
    What's the better tool for this job? Thanks
  2. pajeff02
    pajeff02 Veteran Member
    118
    Aug 16, 2015
    Mansfield, PA
    I run a cone style stiff wire wheel in an angle die grinder and it chews through rust and scale pretty well. Be careful though as the wheel wears out the wires start to fly and are like mini arrows.
    Another choice would be an air needle scaler. It has replaceable rods that hammer away the rust and scale. I actually need to buy one of these for my garage.
  3. daddio4048
    daddio4048 Veteran Member
    823
    Jan 21, 2013
    Valdosta,Ga.
    I use a pressure washer that has a adapter on the tip that sucks up sand to blast without all the dust. Does a good job.All you need is safety goggles for protection.
  4. pajeff02
    118
    Aug 16, 2015
    Mansfield, PA
    ^^ Never heard of this. Will have to check it out as that would be a whole lot cleaner than with my pressure pot blaster. Comparable results?
  5. 1971SS
    1971SS Veteran Member
    724
    Feb 5, 2011
    eastern NC
    Need more info...
  6. pajeff02
    118
    Aug 16, 2015
    Mansfield, PA
  7. daddio4048
    823
    Jan 21, 2013
    Valdosta,Ga.
