Rustorbust's Turbo Big Block
Discussion in 'Project Progress' started by rustorbust, Nov 25, 2012.
  1. rustorbust
    rustorbust Veteran Member
    242
    10
    Dec 14, 2009
    San Diego
    Thought its about time I started a build thread for my ride. Bought the car a few years back as a stock 305 car from a buddy. Since it has got a 10 point cage, 9" rear all strange hardware with a spool and 3.55 gears, Caltracs, turbo 400 with a transbrake. Basically worthy of supporting a healthy motor setup. It has sat quite a bit over the last year but I have really ramped up getting it back together now. The motor is a 468 4 bolt block, factory steel crank, good set of rods and forged flat tops. The heads are a set of opened up 049's. Turbo solid roller cam i bought off a member from another forum. The turbo is an garrett tv8403. It Will be fuel injected with a megasquirt setup and will run on e85. I finished fabbing up the headers this weekend and im waiting on parts to finish up the cold and hot side. Ill post more pictures as I move along with it....
    and this is where im at with things now....
  2. rustorbust
    242
    10
    Dec 14, 2009
    San Diego
    Im gonna try and get the rest of the fab work finished up by xmas. I'll post more pictures as I go along.
  3. Turbo70Camaro
    2,141
    115
    Jan 7, 2005
    so cal
    Looks good but a little worried about the small radiator, if any street driving is in the mix your gonna have issues.
  4. rustorbust
    242
    10
    Dec 14, 2009
    San Diego
    Ya I know, I'm gonna route all the other piping so that if need be ill buy another afco with the outlets just the opposite and re-route the downpipe and mount it on the other side of the turbo.
  5. 973800CamaroRs
    973800CamaroRs Veteran Member
    702
    Nov 27, 2011
    Frederick Maryland
    From a 305 to this.... Dear god lol.
  6. 72Camaro396
    72Camaro396 Veteran Member
    135
    Dec 16, 2005
    Toledo, Ohio
    Very nice. When you ordered your caltrac springs what ride height did you go with? Stock or what? Also what size rear tire? Thanks!
  7. rustorbust
    242
    10
    Dec 14, 2009
    San Diego
    Thanks, the springs are the stock height ones and the slicks are 28x10.5
  8. GOLF72
    GOLF72 Veteran Member
    2,186
    Jan 11, 2010
    CORONA, CA
    Oh man...that is going to be a beast.
  9. Throttle
    Throttle Veteran Member Gold Member
    1,342
    Feb 2, 2002
    Dripping Springs ,Texas........USA
    Cool setup, I didnt want to go with the side mount radiator on mine.. Worried about over heating.. :(
  10. rustorbust
    242
    10
    Dec 14, 2009
    San Diego
    Ya I'm a little worried about it. It's probably more than likely that its gonna have cooling issues so I have been fabbing everything up so that all I'd have to do is re-route the down pipe and ill put an identical afco on the other side of the turbo and have a twin radiator setup....
    Made a little more progress tonight
    Gonna put this in as a muffler, maybe it'll take the edge off. It's a flowmaster outlaw series muffler
