S10-Blazer rear disc conversion
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by woody80z28, Jan 21, 2008.
  1. Skip Fix
    Skip Fix Veteran Member
    1,949
    Mar 21, 2007
    Katy,Texas
    I used tabs like the JEGS ones from Speedway to add a flex line to the rear discs I have -basically a TA setup with "front" metric calipers on it.
  2. Knuckle Dragger
    Knuckle Dragger Moderator Staff Member Lifetime Gold Member
    12,498
    102
    Nov 2, 2002
    Waddell AZ
    What did you do for a parking brake? Delete?
  3. Skip Fix
    1,949
    Mar 21, 2007
    Katy,Texas
    Delete! This is a race car.
    Although Wilwood now has a rear disc setup using the metric caliper and a inside drum/rotos E brake setup.
  4. 70 gsconvt
    70 gsconvt Veteran Member
    1,102
    Sep 30, 2009
    Wadsworth, OH
    Is this 11.6" rotor the biggest or best option money-wise for the rearends? Or is there a larger factory setup that can be fit? I have front and rear C5 Corvette calipers that I got off someone dirt cheap.
  5. Philip
    Philip Veteran Member Lifetime Gold Member
    1,798
    May 30, 2006
    Marana, AZ
    The 98 - 02 Camaro brakes are 12" rotors. For most applications a 17" wheel will be needed to clear the caliper.
  6. 5spd540
    12,283
    Sep 19, 2009
    Guyton, GA
    I have 16in wheels and 98 LS1 rears on my car
  7. Philip
    1,798
    May 30, 2006
    Marana, AZ
    Good to know, the Torque Thrust II in 15x8 almost fit when I installed my rear brakes, a spacer or caliper grinding would have been needed.
  8. 5spd540
    12,283
    Sep 19, 2009
    Guyton, GA
    My car has torque thrust on it
  9. 10-4onthe79
    10-4onthe79 New Member
    Apr 21, 2012
    Des Moines, Iowa
    Has Anyone had any issues with the wheel not centering itself on
    the axel flange after the rotor is installed? Everything bolts up just
    fine, but I find I have a little play in the wheel when the lug nuts
    are loose when the rotor is on and non when the wheel is mounted
    without the axel.
    It looks like the distance of the flange that is left is the same as the
    pics on this forum. I'm using TA snowflakes and maybe camaro wheels fit different?
    I've got a ton of pics posted here:
    http://transamcountry.com/community/index.php?topic=50695.0
    Somebody mentioned using concentric rings, has anyone tried this?
    Not sure how to proceed.
  10. Philip
    1,798
    May 30, 2006
    Marana, AZ
    What you are experiencing is normal, the very end of the hub is a little smaller than the base where the wheel used to sit. Most after market wheels are not hub centric, the lug nuts will center the wheel hold it tight provided they are not bottoming on the studs. If with the nuts tight the wheel is loose the studs are too long.
