SCAT crankshaft cleaning
Discussion in 'Engine Topic' started by lapedr, Dec 27, 2016.
  1. lapedr
    lapedr Veteran Member Gold Member
    464
    Jan 28, 2003
    Pembroke, GA
    So what is the best way to clean off the anti-rust preventative that SCAT applies to their crankshafts when they are shipped? This is my first bottom end build and I don't want to screw up this new crank.
  2. frankz
    frankz Veteran Member
    2,057
    Aug 24, 2009
    Illinois
    I would shoot it with brake clean
  3. lapedr
    464
    Jan 28, 2003
    Pembroke, GA
  4. tom3
    tom3 Veteran Member
    10,725
    61
    Aug 1, 1999
    ohio
    And always a good idea to really clean out the oiling holes, never know what might be left in one, do some major damage.
  5. lapedr
    464
    Jan 28, 2003
    Pembroke, GA
    Good advice I am gonna try some paint stripper first and if that doesnt work then some adhesive remover since it is sticky to the touch
  6. 71RS/SS396
    71RS/SS396 Veteran Member
    2,578
    19
    Aug 26, 2008
    Wake Forest NC
    Try WD-40 to remove the rust inhibitor, spray it on and let it soak for awhile.
  7. MyBoTy
    MyBoTy Veteran Member
    1,565
    9
    Feb 9, 2002
    Lubbock, Texas USA
    Make sure you use rifle brushes to clean the oil passages, sometimes some crud gets left in those...
  8. CNC BLOCKS
    CNC BLOCKS Veteran Member
    1,617
    Oct 11, 2004
    NORTHEAST
    If its a cast crank its really not a polished finish and should be polished. Is the crank balanced ?? If its not balanced for you pistons and rods its should be balanced.
    Forged cranks have a much better finish then the cast cranks.
    Brake clean brushes should work fine.
  9. lapedr
    464
    Jan 28, 2003
    Pembroke, GA
    Its a cast 383 stroker crank that came with rods. I will try the wd-40 method first, then if it takes the stuff off I will polish each journal until they shine using maybe 2000 grit wet sandpaper. I finished making a pistion pin jig today to hold the piston in place with an adjustment screw so after I heat up the rod end I can slide the wrist pin right through to the stop. I saw the idea off of the Goodson site.
  10. CNC BLOCKS
    1,617
    Oct 11, 2004
    NORTHEAST
    So your not balancing the crank ??
