Sea Foam: Any Thoughts?
Discussion in 'Tips 'n' Tricks Topic' started by slayer021175666, Jul 18, 2016.
  1. slayer021175666
    slayer021175666 Veteran Member
    1,055
    40
    Feb 29, 2016
    Idaho
    Anyone have thoughts about Sea Foam?
    Does it work?
    How to apply?
    Different uses, etc.?
    Thanks
  2. harbone66
    3,405
    225
    Feb 15, 2011
    Central Illinois
    I use it in all the gas for my lawnmowers, ATV's, chainsaw, weed wackers, etc.
    It helps the fuel last longer on gas powered equipment that do not get used that often and does a good job of keeping the carbs from gumming up.
    I also put it in my car before it gets stored in the winter.
  3. DB Z28
    DB Z28 Veteran Member
    494
    14
    Nov 30, 2003
    Fond Du Lac
  4. mickstan
    mickstan Veteran Member
    927
    Jun 11, 2012
    E'ville, IL
    Yep, +1 here too. Been using it for years in all the engines fuel. I've soaked small engine carbs in the stuff. It works!
  5. mech393
    mech393 Veteran Member
    763
    Aug 9, 2003
    belvidere illinois usa
    if you decide to run it in your cylinders to soften carbon on the pistons or valves do it out side and be prepared for a lot of white smoke, it will look like your cars on fire with all the smoke.
  6. COPO
    15,976
    190
    I put some in the gas tank then the rest I run through a spray container I fill with compressed air. Or you can dump the whole can in the tank. The empty can makes for a good oil catch can.
  7. Sledhed
    Sledhed New Member
    19
    Jun 14, 2015
    bellefonte pa
    Been using it for years with no problems and in most cases good results.
  8. sparkyboy
    sparkyboy Veteran Member
    242
    15
    Feb 4, 2015
    aurora, co
    What's better for dumping down the carb, sea foam or marvel mystery oil?
  9. cali cruzer
    cali cruzer Veteran Member
    2,659
    53
    Mar 24, 2002
    Henderson/Las Vegas, NV
    If you dump a can in the tank does it still smoke a lot?
  10. COPO
    15,976
    190
    Not at all.
    MattyZ28 likes this.
