Seat Track Original Finish
Discussion in 'Original Drivetrain Topic' started by camaro73lt, Feb 8, 2019.
  1. camaro73lt
    camaro73lt Veteran Member
    916
    Feb 6, 2003
    Hanover, PA
    I did a search but didn't find anything conclusive.
    Can someone confirm what is the correct finish for original front seat tracks?
    I have a set that is surface rusted at the "feet" and not sure to paint or just blast / clear coat, etc.
    Thanks
  2. rotinrob
    rotinrob New Member
    8
    Oct 2, 2018
    My 1970 were just plain (and rust) no sign of finish anywhere except the latch was zinc or otherwise plated (cad?). Springs showed some color but can't remember at this time what colors but the springs where different colors. I disassembled them, soaked them in evaporust for a couple of days, hand buffed the black residue off with some phosphoric acid and steel wool and satin clear coated. Same with the springs but stretched them a bit before soak and paint.
  3. Twisted_Metal
    26,308
    618
    Surface rust IS the original finish. ;)
    I don't think they were coated with anything when they were produced or installed.
    Blasting them will change the finish.
    Electrolytic rust removal would probably leave them as close to factory as you will get.
    You could probably use Rem-Oil (or clear coat) on them to keep the surface rust at bay once you had them cleaned up.
    I guess it depends upon how "correct" you want them to look.
  4. rotinrob
    rotinrob New Member
    8
    Oct 2, 2018
    Should have saved the time and effort of the disassembly and just left them rusty. Really was a pain for so little.
  5. 70lt1z28
    2,639
    392
    Oct 3, 1999
    Beavercreek, Ohio, USA
    BillyDean7173 likes this.
  6. TommyRS70
    TommyRS70 Veteran Member
    960
    33
    Jan 31, 2004
    KY
    Here are my originals after I cleaned them up. Sprayed with Boeshield. Repainted the return springs 0212181713.jpg 0212181651.jpg 0212181646a.jpg 0212181646b.jpg
  7. mallard
    mallard Veteran Member
    237
    26
    Oct 3, 2013
    SK, Canada
    Wrong thread topic?
  8. camaro73lt
    916
    Feb 6, 2003
    Hanover, PA
    Thanks for the info and resto tips. Definitely going to try the Evaporust.
  9. zfool
    zfool Veteran Member
    533
    8
    May 19, 2014
    Rochester, MN
    I’ve been thinking of trying Fluid Film to coat them when I do the seats next fall. I’m really impressed with that stuff on other applications.
