Seized Idler Arm 1970 Camaro Z28
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Rich Gershman, Oct 16, 2018.
  1. Rich Gershman
    Rich Gershman New Member
    15
    May 21, 2017
    Recently did a complete front suspension rebuild. Purchased complete package from Ecklers. As I was attaching the idler arm to the link I noticed that the idler arm could not be rotated by hand, I had to hit it with a heavy hammer in order to move it. I thought if I greased it, it would move but that didn't help. The car is on the ground with the work completed and it takes a lot of effort to turn the steering wheel... way more than normal. Has anyone experienced this problem, did I just get a seized idler arm?
  2. 70lt1z28
    3,017
    532
    Oct 3, 1999
    Beavercreek, Ohio, USA
    "Hitting it with a heavy hammer" seems a bit much, but my NOS one is really stiff. Putting it in a vice on the vertical part and grabbing it with my hand its tough getting it to move. If I had to guess I would say about 10 to 30 foot-pounds of torque to get it to turn.
  3. Rich Gershman
    15
    May 21, 2017
    Thanks for the response. I would guess that in order to move my arm it would take 100 ft/lbs. I will buy a new one!
  4. badazz81z28
    16,145
    374
    Las Vegas, NV
    You really shouldn’t be able to rotate ball and socket joints by hand. I agree excessive...something isn’t right.
