Serpentine set up. Gen 1 SB
Discussion in 'High Tech Retrofits' started by 8pack, Jun 12, 2014.
  1. ChevyReb
    3,777
    13
    Feb 4, 2003
    SC
    Bonzo is that a length of all thread out of the hole under the compressor? I was looking a that last night. I am thinking of haveing my guy mill down the AC delete pulley and replace the ribbed pulley on it with a replacement tensioner smooth pulley like it looks like you did where the smog pump went.
    Did you put a nut on the inside to tighten it up against the head or just put a nut on the front of the bracket and that pulls the top smog replacenet pulley and the serpentine bracket tight to the head?
    I have looked for a larger diameter pulley with raised lips on the front and back but so far no luck!
  2. BonzoHansen
    19,628
    896
    Jun 1, 2005
    Scott from Hamilton, NJ
    yes that is threaded rod but it does not appear I used it.
    My a/p delete is smooth, that is a GM part. I'd have to look for the part number
    today:
    mock up:
    these are gm with grooved pulleys.
  3. ChevyReb
    3,777
    13
    Feb 4, 2003
    SC
    Darn, now you have me back to guessing how to bolt this thing in again. :screwup:
    Is the 10186167 pulley smooth where the belt rides?
  4. BonzoHansen
    19,628
    896
    Jun 1, 2005
    don't think so. check the part numbers in the setup GMPP sells.
  5. ChevyReb
    3,777
    13
    Feb 4, 2003
    SC
    So you run your flat side of the belt on the ribbed pulley under the AC compressor???
  6. BonzoHansen
    19,628
    896
    Jun 1, 2005
    just like the pic above, flat against flat, ribbed against ribbed. the AIR delete pulley just puts some tension on the belt to avoid flapping at high RPM. some 3rd gen guys say just get a shorter belt but IMO that is not the way to fly.
  7. 8pack
    2,623
    149
    Aug 29, 2007
    Western, MA
    ChevyReb, I am trying to figure out what you are asking. I just installed the set up. It is exactly as Bonzo has it.
    The Air pump delete is a bracket that bolts in where the Air pump went and has a smooth pulley mounted to it. The back of the belt runs on the smooth part of the pulley.
    My kit came with that smooth pulley.
    I think this is what you are looking for?
    http://www.summitracing.com/parts/nal-10129569
    I had to grind the ends on mine a bit to get it to fit. If you read the reviews it sounds like I am not the only one.
  8. junkyardZ28find
    793
    8
    Mar 4, 2012
    des moines, iowa
    There are two types of RH serpentine brackets-the truck versions usually don't have the smog provision and are a cleaner look. And, there are actually at least three versions of the LH bracket too-I've got 2 which allow for a 140A alternator with NO mods required-very hard ones to find and they aren't part of any GM kit but they were on Caddy's for 2 years only. Its funny GM offers only one replacement kit even though there were many varieties of it.
  9. BonzoHansen
    19,628
    896
    Jun 1, 2005
    that is probably the one I have.
    I love the reviews.
    Dear idiots, you used the wrong belt and put it on wrong. Nice HP gain lol
  10. ChevyReb
    3,777
    13
    Feb 4, 2003
    SC
    I thought I would add this question in this thread since it is directly related. When retrofitting the serpentine system over to the older engine, how to you determine how to chose the proper belt length? There are register marks on top of the tensioner, but where is the sweet spot it needs to be for proper tension to be applied?
    In this pick there is now load on the spring, it is in its home position with no belt on it. I need to find out where the marks should line up so I can measure the length while holding preasure to align the marks where they should be.
