Setting up prop valve adjustable
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by badazz81z28, Apr 13, 2019.
  1. badazz81z28
    15,760
    279
    Las Vegas, NV
    What’s the best way to do this? I thought I had it set up perfect last time but coming to a screeching halt, the front brakes locked but the rear did not. This extremely hampered my ability to stop. How do I adequately test without creating flat spots on my tires?
    hubedobeedo likes this.
  2. Dave Nelson
    Dave Nelson Veteran Member
    3,959
    1,403
    Dec 19, 2003
    Vineland N.J USA
    Are there drums on the rear?
  3. badazz81z28
    15,760
    279
    Las Vegas, NV
    Disc
  4. Dave Nelson
    3,959
    1,403
    Dec 19, 2003
    Vineland N.J USA
    Just had this problem with a friends car, but it was disk/drum. We had to install a 10lb residual valve to cure the bias.
  5. badazz81z28
    15,760
    279
    Las Vegas, NV
  6. Scott51
    Scott51 Veteran Member
    583
    58
    Jan 2, 2012
    New Zealand
    Wilwood include some instructions with their valves that should help https://www.wilwood.com/PDF/DataSheets/ds715.pdf (half way down pg2)
    A specialised brake and suspension workshop with brake rollers/Dyno can usually dial them in as well (ideally find someone that does a bit of work on race cars)
  7. Zoomin
    Zoomin Member
    44
    Aug 5, 1999
    Oklahoma City, OK USA
    Locking up the brakes is not the fastest way to stop, and you sure don't want the backs locking up first.
  8. Skip Fix
    Skip Fix Veteran Member
    2,135
    9
    Mar 21, 2007
    Katy,Texas
    Gravel parking lot won't flat spot them.
  9. dcozzi
    dcozzi Veteran Member
    2,521
    145
    May 1, 2002
    Phoenix, AZ
    That's an excellent point! It will quickly get you to a baseline to fine tune from without destroying your tires along the way.
  10. hubedobeedo
    hubedobeedo 3rd times a charm
    163
    31
    Jul 18, 2013
    Huntertown,IN
    i have seen online that some of the adjustable prop valve sold are not built right. cannot think of the brands remember there caused inconstant results.i have a ssbc brand but have not had car out yet to trial.
