Sharkbite plumbing fittings.
Discussion in 'The BS Topic' started by Chevrolaine, Apr 1, 2014.
  1. Earlsfat
    Earlsfat Veteran Member Lifetime Gold Member
    1,541
    19
    Jun 14, 2006
    Whut?
    HHHHAAAAAAAAAAAAAAAAHAHAHAHAHAAAAAAAAAAA. Thanks, I needed that laff.
    That's what I'm thinking... someone bumped it while cleaning and hit the release ring and it didn't seat again after being bumped. It was fine for about 3 years, and then.... it wasn't, lol.
  2. Earlsfat
    1,541
    19
    Jun 14, 2006
    Whut?
    I think my point is... IMHO - It's not worth the risk if it's in a wall. By the time you know there's a problem, you have a PROBLEM.
  3. mjoc
    mjoc Veteran Member
    3,511
    Apr 29, 2003
    Sherman Oaks, Ca
    I would never use PEX It is a cheap crappy product. Sharkbite is only good to 280 PSI and solder joints are good to 600+ and higher temps as well.
    Over time the plastic in the fittings will dry out, corrode. A good plumber can solder in the tightest spots without having to worry about burning anything. Or you use a thermal blanket.
    Michael
  4. cyberswap
    cyberswap Veteran Member
    1,437
    Dec 14, 2002
    kentucky
    i have used sharkbites many times...but i wouldnt do it in an enclosed wall..just my opinion
  5. John Wright
    14,681
    208
    Aug 9, 2002
    Rustburg, Va
    I like the fire blankets, I also keep a spray bottle with water in it handy...just in case things get a bit too warm.
  6. mjoc
    mjoc Veteran Member
    3,511
    Apr 29, 2003
    Sherman Oaks, Ca
    That helps also. I do the same. forgot to mention it.
    Michael
  7. At Home Camaro
    At Home Camaro Veteran Member Lifetime Gold Member
    731
    Mar 13, 2002
    Md
    Agree with this... they are quite expensive if you start needing many for a project. And I'd be reluctant to close one up in a wall. I've always enjoyed sweating pipe, although I don't get paid by the hour.
  8. Jimmac
    Jimmac Veteran Member
    369
    67
    Dec 24, 2013
    tucson az
    When I did my bathroom I installed them. Turned on the water and the one I felt went rogether wrong sprung a leak. My fault. But still a leak. I ended up sweating it all together. I installed my water conditioner outside with two of them two years ago. Works fine. Jim
  9. sprink
    sprink Veteran Member
    500
    118
    Apr 27, 2008
    ffx, va
    Plumber. I've used them w/ no problems. Most always where accessible though.
    I would sweat any fittings being concealed. If he's good, he can do it or pre-fab/sweat some of it or even use some soft copper.
    We usually use whats already in the house, copper, cpvc or pex.
    I've got my doubts about the long term service of cpvc (could get brittle) & pex.
    A little concerned about being able to rotate shark fittings or pex once together also! It is nice not having to get rid of all the water.
    Wasn't that long ago they thought poly (quest) pipe was the next big thing!
  10. Shizzle
    Shizzle Veteran Member
    2,385
    485
    Aug 1, 2012
    oak lawn, illinois
    Family cottage near Kalamazoo, the cousins installed Pex, 5 years later they redid everything in copper because it got brittle and was cracking when they opened & closed the place for the season.
