shift knob with microswitch?
Discussion in 'Electrical Systems' started by ULTM8Z, Feb 7, 2017.
  1. ULTM8Z
    ULTM8Z Veteran Member
    8,331
    49
    May 19, 2000
    Los Angeles
    Anyone know of a factory gear shift knob for 73-81 shifter (or at least can be adapted) that has a built in microswitch?
  2. Twisted_Metal
    25,389
    330
    There isn't much of anything to replace the knob in the aftermarket.
    (Maybe someone has produced something recently but there was nothing when I was searching a few years ago.)
    A wire would have to be run down the outside of the shifter shaft as there is a moving rod inside of it.
    I guess you could hollow out a spot in the knob (for a switch) and cut a groove down the side for the wiring. (And backfill the groove with epoxy or something.)
  3. ULTM8Z
    8,331
    49
    May 19, 2000
    Los Angeles
    Yeah either that, or design something. I have access to some solid modeling software... could simply 3D print it at that point.
    But if something is already available....
  4. ULTM8Z
    8,331
    49
    May 19, 2000
    Los Angeles
    One of the thirdgen guys said this particular knob is out of a Pontiac GTP, but not much more info than that. Anyone here know?
  5. 71flh
    71flh Veteran Member
    916
    14
    Jun 1, 2010
    DFW
    My thought is someone could rob contacts from whatever, drill holes and make it happen w/ a bit of epoxy. Then again w/ an early shifter, as stated above, wire is exposed. I tend to wonder why people buy an old car and then work to make it a new car.
  6. ULTM8Z
    8,331
    49
    May 19, 2000
    Los Angeles
    I simply like the new car driveability but prefer the old car styling. Pretty much the definition of Pro-Touring.
  7. NeoNeuro
    NeoNeuro Veteran Member
    158
    Aug 4, 2014
    Panama City, FL
    I believe Gear Vendors sells some shift knobs with switches.
  8. ULTM8Z
    8,331
    49
    May 19, 2000
    Los Angeles
    Yeah, I saw their stuff...
