Shock guru's help me adjust my Koni's
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by sevitz5, May 30, 2014.
  1. sevitz5
    sevitz5 Veteran Member
    1,618
    Feb 27, 2011
    Middle Point, Ohio
    I understand how to adjust them (compress them and turn) what I don't understand is what I am adjusting. I have the 8040-1017 classics. I am having some issues with my fenders rubbing my tires when getting out of the gas. Do I want the shocks set stiffest to minimalize this or softest? I know somewhere in between is where I want them, but not sure. Help me out guys....thanks.
  2. COPO
    17,633
    651
    I'd say stiffer. I had Koni's on for yrs before the rears seized up.
  3. sevitz5
    1,618
    Feb 27, 2011
    Middle Point, Ohio
    Any other opinions?
  4. 8pack
    2,599
    146
    Aug 29, 2007
    Western, MA
    Keith told me to set them to turn full to the highest setting and then back off 1 turn for the fronts and 1 1/4 turn for the rears. That is with 175lb rears and his fronts which I don't know the spring rate on.
  5. ks71z28
    ks71z28 Veteran Member NastyZ28 Sponsor NazstyZ28 Sponsor Lifetime Gold Member
    2,144
    39
    Oct 10, 2004
    chico, ca, usa
    The Koni's are rebound adjustable ONLY. If the car dives too much under braking, then the shocks cannot help you. You can stiffen the rear which may help. Your coils may be a touch on the light side for serious performance. Our coils are about 60-75# actual higher rate
