shock leaf spring plates needed
Discussion in 'Swap Meet Section' started by perkalator, Mar 27, 2018.
  1. djorgensen3
    djorgensen3 Veteran Member
    489
    52
    Oct 15, 2009
    Peoria, Az
    I have a set too that I am willing to part with.
  2. laspisa
    laspisa New Member
    10
    Feb 26, 2011
    Kailua, HI
    How much to ship to 74003? Are they stock ones? Thanks!
  3. djorgensen3
    489
    52
    Oct 15, 2009
    Peoria, Az
    They are stock ones. I sandblasted them and put a coat of primer on them to prevent rust. They could probably use a better clean up job. I'll check into shipping as soon as I can.
  4. laspisa
    laspisa New Member
    10
    Feb 26, 2011
    Kailua, HI
    Sounds good! Let me know
  5. perkalator
    perkalator Veteran Member
    1,025
    90
    Aug 27, 2014
    kennewick wa
    Thanks mark.
  6. Ihada70Z28B4
    Ihada70Z28B4 Veteran Member
    162
    12
    Oct 4, 2002
    Buffalo,NY,USA
    I used the OER ones but would have preferred the thicker plates your traction bars have. You can cut them off the bars and have the much stronger plates that won't distort when you tighten them like the OEM and OER ones do. I have also found small cracks from the locating hole outward in more than a few stock ones.
  7. mark wagner
    mark wagner Veteran Member
    2,129
    19
    Jul 31, 1999
    Saylorsburg Pa. USA
    you're welcome
