shorty spark plugs
Discussion in 'Engine Topic' started by 1981z28owner, Apr 3, 2010.
  1. 1981z28owner
    1981z28owner Veteran Member
    2,562
    Nov 28, 2005
    midwest
    do they made a short spark plug for 14mm .750 reach? my new headers hit my plugs on my Dart Pro 1 alum heads and i am currently using AR3933 plugs
  2. 1981z28owner
    2,562
    Nov 28, 2005
    midwest
    i found that accel u-groove has them, but cant figure out how hot of a plug to use.
  3. z28rod
    z28rod Veteran Member
    4,473
    Apr 30, 2009
    hopewell junction,ny
    i use ngk ur 4 or 5 [lugs, small and cheap and run great..
  4. 1981z28owner
    2,562
    Nov 28, 2005
    midwest
    are they shorter than normal?
  5. hhott71
    hhott71 Veteran Member Lifetime Gold Member
    14,375
    Mar 30, 2001
    Joplin Mo. 64801
    Step up to Hedman Hedders # 65104
    They clear angle and straight plugs.
    1.75" primaries and fit VERY well.
  6. jims73z
    jims73z Veteran Member
    1,220
    Jul 22, 2000
    laguna niguel,ca
    Accel shorty plugs here also for my trick flow angle heads
  7. z28rod
    4,473
    Apr 30, 2009
    yes same or shorter than accels and 1/4 of the price, and work great...
  8. Type73LT
    Type73LT Veteran Member
    101
    Jun 15, 2009
    Bethlehem, PA
    I just received a set of 416s....the shorty accel plugs and they were the same as the champion 89's. Standard size.
  9. Are these the ones?
    http://www.summitracing.com/parts/NGK-6630/
    Would they be good for Vortec heads and what gap? My wires are becoming toast too fast. Thanks
  10. z28rod
    4,473
    Apr 30, 2009
    accel makes short plugs and stnd length plugs, you must order the shorties, check for the correct accel part number....
