SHOULD I UPGRADE MY EXHAUST?
Discussion in 'High Performance Modifications' started by Z28-79, Jul 22, 2019.
  1. Z28zz383
    Z28zz383 Veteran Member
    807
    11
    May 11, 2012
    Florida
    I have been running the pypes 2.5 transverse for several years. Their mandrel bent X pipe system is the "go to" for easy clean install and good clearance. I have no regrets. If planning to go up to over 450 hp, a 3'' system might be a good upgrade. Or use the pypes elec. cut outs for when you need more flow. I wanted a good sounding system, but still be able to enjoy the ride and stereo. Pypes has delivered. No drone!
    John Wright and Z28-79 like this.
  2. G72Zed
    G72Zed Veteran Member
    1,023
    216
    Sep 8, 2015
    Yep, it's a choke point for sure, on both points, pipe size, and most likely those "glasspacks". A nice 2.5" mandrel bent exhaust/kit could support up to 500hp, mufflers need to flow in the 550 CFM range each at that HP (assuming dual) for a close to "zero HP" loss system.
    If your getting a muffler shop to build it with compression bends, go 3".
    Z28-79 likes this.
  3. 1980RS
    1980RS Veteran Member
    3,153
    508
    Jun 17, 2006
    MN
    Not true bout going from 2.5 to 3" exhaust. I have both systems for my street car and the 2.5"feels stronger the 3". Remember exhaust is different than the intake side, just like headers bigger is not better for exhaust. I have had 1 5/8" headers that makes more power than the big buck Hooker Super Comps, and these are the cheapo ones. You might loose maybe 10hp but if your system is 2.5 mandrel bent with some real good flowing mufflers that about the drop I would expect but the torque numbers will be pretty good. Look for the Engine masters video on mufflers and exhaust, it was pretty eye opening.
    Z28-79 likes this.
  4. 77 cruiser
    77 cruiser Veteran Member
    535
    24
    Nov 17, 2006
    Frostbite Falls MN
    Especially the smashed header tests.
    RS1979 and 1980RS like this.
  5. John Wright
    14,637
    198
    Aug 9, 2002
    Rustburg, Va
    I used Pypes 3" mandrel bent Stainless steel X system, over the axle and out the back with the factory style hockey stick tips. Works great, I modified it some for my single turbo car but for a stock arrangement, it should work great.
    Z28-79 likes this.
  6. nova75mike
    nova75mike Veteran Member
    354
    Mar 20, 2008
    Etters, PA
    x2 on the 3" Pypes system with X pipe and Race Pro's. looks very nice and with the help of a buddy, was installed in about an hour. was worried about it fitting around the sway bar, but had PLENTY of clearance.
    Z28-79 likes this.
  7. 1980RS
    3,153
    508
    Jun 17, 2006
    MN
    That was my favorite video too.
  8. John Wright
    14,637
    198
    Aug 9, 2002
    Rustburg, Va
    I remember that video, it amazed me how much they smashed on those header tubes before the power was effected. It made me feel a little better about denting the headers for socket clearance for the header bolts.
  9. Bandit723
    Bandit723 Veteran Member
    3,145
    462
    Oct 1, 2016
    Waupaca WI
    Well here is muffler shop done pipes vs internet mandrel bent pypes. Not sure what a few krinkles in the tubes makes performance wise but i did measure both the bent pipes vs the mandrel bent ones they are the same. Down side is the pypes stuff leaks really bad and did not fit all that well. I am sure it can be plugged up but is it worth your time. Upside the shop tail pipes run out the back of the car fully "no fumes into the trunk" and clears the gas tank and body with room to spare. No rattles at all...
    1980RS and Z28-79 like this.
  10. G72Zed
    1,023
    216
    Sep 8, 2015
    I also found it very interesting, maybe taking "time" like 10-12 seconds to hit the target RPM with a 300 RPM/sec sweep somewhat camouflages or screws the data.
    Static Dyno data vs Dynamic results can be on opposite sides of the scale.
    Would be interesting if they did the same test within 10 seconds hitting the sweeps 3 or 4 times to max rpm simulating a 3 spd auto or 4 spd 10 second 1/4 pass. One of the fancy dynos at BLP or Hendricks would be interesting, measuring "time" instead of HP/TQ may uncover something, not to mention the cyl to cyl variations.
