Simple floor pan question.....
Discussion in 'Body Restoration' started by bigdav160, Feb 14, 2010.
  1. bigdav160
    bigdav160 Veteran Member
    592
    Jan 11, 2006
    Klein Texas
    My '73 Z-28 is surprisingly rust free.
    The only spot is several pin holes in the drivers footwell area, a small corner of the dash near the VIN and another quarter sized hole on the right cowl.
    My question is the floor section reproduced? I see full sections offered that look right but the small panels look wrong.
    Of course, it might be just as easy to patch the few square inches of rot but the other metal in the LF floor is looking thin.
  2. 76 camaro car
    76 camaro car Veteran Member
    350
    Nov 15, 2009
    Jacksonville,Fla.
    The floor sections are reproduced,but unfortunately the toe boards are not. most of the time if you have rusty floor pans the toe boards are also rusted. Your only option with them is to fabricate something or find a donor car.
