Slightly high LP AC reading
Discussion in 'High Tech Retrofits' started by badazz81z28, May 1, 2019.
  1. badazz81z28
    16,979
    518
    Las Vegas, NV
    Charged my VA system...did it by weight even though every other AC pro says to use pressure. Well my low pressure side reads about 25 psi..VA wants 6-18psi...high pressure is normal at ~150. It’s about 70 degrees in the shade. AC blows colds...what does the high LP reading indicate? Too much refrigerant? Too little?
  2. badazz81z28
    16,979
    518
    Las Vegas, NV
  3. 75Maro
    75Maro Veteran Member
    435
    18
    Mar 31, 2008
    Dallas,Tx
    High side pressure seems off also.
    Where are you located.
    General rule of thumb is HS should be ambient x2 plus 40-50.
  4. ULTM8Z
    ULTM8Z Veteran Member
    9,194
    357
    May 19, 2000
    Los Angeles
    High side is showing 275, not 150???
  5. 75Maro
    435
    18
    Mar 31, 2008
    Dallas,Tx
    I would evacuate the system
    Pull a vacuum for 20 minutes if you didn’t already do this then pull refrigerant in through low side (suction side) until the gauges read what you want.
  6. badazz81z28
    16,979
    518
    Las Vegas, NV
    The gauges have inner dials depending on what you’re mesuring. I’ll take a better picture. The second inner dial in red is R134A #s.
  7. badazz81z28
    16,979
    518
    Las Vegas, NV
    51A153FA-B96E-4225-828A-C36D900F1D09.jpeg ECF472A1-0362-43C4-A79D-7265159336E7.jpeg Here you go, so when you see 250 on the outer dial R134A is ~148
    The low pressure is closer. Outer dial says 25 it’s about 29 on the R134A. Low pressure seems a little high for VA, but normal for rule of thumb. In Vegas today it was about 75 deg, but I was in my garage where it was probably closer to 70deg or slightly less.
  8. badazz81z28
    16,979
    518
    Las Vegas, NV
    Static pressures are about 90 on both gauges
  9. Mike-78 Z-28
    Mike-78 Z-28 Veteran Member
    1,909
    Mar 4, 2003
    ElDorado Arkansas
    Weight is the only correct way, no manufacturer ever goes by pressure. Pressure can be all over the place with whatever the temp is. Suicide cans and top offs try to go by pressure because it's just a guess if they don't know how much is left in the system.
  10. Mike N
    2,774
    542
    Jan 13, 2002
    Spencerport, NY.
    Looks like it's overcharged to me.
