So I opened a cam of worms, now I'm nervous!!!
Discussion in 'High Tech Retrofits' started by QUAKE_WARS, Jul 20, 2009.
  1. Todd80Z28
    11,553
    242
    Jun 11, 2002
    Northern VA
    The low/high brake pedal stud is the difference in mounting points for manual or power brakes.
    Manual brakes put the stud higher- more leverage, but more pedal travel. Power brakes have the stud lower (further away from the mount/pivot point)- less leverage (don't need it with a big booster), but less pedal travel.
  2. QUAKE_WARS
    QUAKE_WARS Veteran Member
    2,021
    149
    Dec 19, 2008
    Yup, i got manual. So needs to go higher:) its crazy whats a 1/2 inch difference makes
  3. drptop70ss
    drptop70ss Veteran Member
    700
    Jul 19, 1999
    NY zip 12538
    on chevelles, novas, and early camaros the lower hole is for power brakes and the upper hole is then used for a sheet metal tab to actuate the brake light switch. Manual brakes used the upper hole and the brake pedal sat high enough to hit the brake light switch on its own. I would think it would be the same with 2nd gens..it is pretty much impossible to use the wrong mounting hole because you have to put the pedal rod out of alignment. It should go straight into the car and pretty much line up with the hole.
  4. QUAKE_WARS
    2,021
    149
    Dec 19, 2008
    Well, Todd did it again. I put the rod higher and the brakes work like a charm.
    All problems solved. Thanks Todd. :bowtie: :bowtie:
  5. Todd80Z28
    11,553
    242
    Jun 11, 2002
    Northern VA
    Glad to help! I'm not able to that often anymore.
    Plus, drptop might actually be correct on original app. It's been 15+ years since I've actually seen a factory manual brake car.
  6. drptop70ss
    700
    Jul 19, 1999
    NY zip 12538
    whatever works is good, as long as the rod isnt binding all will be good to go.
  7. QUAKE_WARS
    2,021
    149
    Dec 19, 2008
    Yea, thanks also. I dont understand how a little bit of angle could be so drastic.
    But putting the rod back in the original location made a world of difference.
    here is the part # for the brake rod needed for the swap.
    more pic's to follow :D
  8. drptop70ss
    700
    Jul 19, 1999
    NY zip 12538
    I edited my original post for future searchers, my memory failed me..I was just under the dash of a chevelle I am building and the lower hole is used for power brakes, the upper hole is for manual brakes.
  9. Lrader99
    Lrader99 Veteran Member Lifetime Gold Member
    894
    Sep 18, 2005
    NW Georgia
    just a little info maybe it will help maybe it wont. mount that T-56 on a polyurethane pad that way there is some shock absorbtion, if at all possible refrain from using a torque arm setup as this torques the case and misaligns the 3-4 syncro assembly, i have replaced my fair share of these, it is def.the weakpoint of the trans. lastly i would use the hurst billet plus it is centered more to the left than any other shifter out there. and i know shifter location is crucial on these. i had one for years in my trans am. had fast accurate shift quality
  10. PolarBear
    1,189
    Apr 24, 2008
    NJ
    It is mounted with a rubber mount, I thin k he has the hurst shifter and there are no torque arms on these cars...
