So I opened a cam of worms, now I'm nervous!!!
Discussion in 'High Tech Retrofits' started by QUAKE_WARS, Jul 20, 2009.
  1. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Okay so I absolutely need a bearing, so my next question is.....
    Do cranks all have this pilot bushing "stop" and proper diameter hole for the pilot bearing??
    Because what I'm guessing here is, mine HOPEFULLY has this, and I just need
    to drill out the center of the crank for the input shaft to go deep enough.
    I've read quite a few people have done this by hand......so I'd think you'd have to be DEAD ON
    if it wasn't to prevent the bushing from rotating out of whack and binding up.
  2. PolarBear
    1,189
    Apr 24, 2008
    NJ
    I dont see how this would be possible, the concentricity would have to be really close (not an engineer so I dont know how much but maybe one thousands?) or the input shaft would rotate and be out of alignment.
    Your car is all together now? You cant just kinda go check? I would image even though it is an (Olds, right?) would still have the provisions for the pilot bushing even though you r car is an auto. I think a crank is a crank, at least where Chevy is concerned. My 88 GTA Auto had the provision for the pilot and I would imagine all chevy is like that
  3. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Yeah my car is in my driveway all together and driveable right at the moment.
    I'm piecing together the parts to do the swap.
    My T56 is here.....just trying to piece together the rest and ensure I know EXACTLY
    what I need to do before I pop it up in the garage in March-April
    A guy on the Olds forum did this and had to drill out his crank , so I'll have to ask him I guess.
  4. BonzoHansen
    19,487
    823
    Jun 1, 2005
    Scott from Hamilton, NJ
    Machines shops can drill crank snouts for balancer bolts (early SBC had press on balancers) with the crank in the engine, I don't see why they can do the back of a crank. **speculation alert**
    Of course it will probably need to be out of the car. Or maybe just the trans needs to be out.
  5. jakeshoe
    8,883
    21
    Dec 8, 2000
    Republic of Texas
    Make up a jig, and let the crankshaft be it's own "engine lathe", set up a cutter bit and machine the crank with the engine running ;)
  6. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    I'd think the engine vibration wouldn't allow that idea Jake. :D
    Maybe I'm wrong......speculating too.
  7. jakeshoe
    8,883
    21
    Dec 8, 2000
    Republic of Texas
    It would actually work if you could make a jig to hold the cutter firmly enough.
    The vibration isn't going to be that much and the crank isn't going to be moving (except rotation) very much in the block. It would work well enough for the accuracy you need.
    But it would cost more in time and materials to make the jig than to pull the engine and crank and do it on a lathe.
  8. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Well I got my answer off the Olds forum.
    So I guess I'll be fine.
  9. PolarBear
    1,189
    Apr 24, 2008
    NJ
    That doesnt look too bad, I guess the input shaft sticks through the bushing a little?
  10. QUAKE_WARS
    QUAKE_WARS Veteran Member
    2,021
    149
    Dec 19, 2008
    Well I just put in the PTFB solid bushings in..:)
    It gave me about 3/4 extra clearance everywhere.
    I would almost have not needed to massage my tunnel
    if this was the first thing I done.
    So before your swap. Replace those worn out bushings!!! :bowtie:
