So I opened a cam of worms, now I'm nervous!!!
Discussion in 'High Tech Retrofits' started by QUAKE_WARS, Jul 20, 2009.
  1. PolarBear
    1,189
    Apr 24, 2008
    NJ
    Regarding the other thread about needing to massage the body, I did the solid body bushings before I did my install and I have an early car too. I had to BFH for the reverse lockout like you did but none of the other spots you showed but I did have to BFH the front of the trans tunnel a little. I think the year car has a lot to do with whether the car needs cutting or just some minor clearencing. But I also used the ATS (Speedtech now) crossmember and I think it sits the trans "up" higher than stock, but I never measured before or after. I have to take the rear suspension apart soon so I will take some measurements then
  2. QUAKE_WARS
    QUAKE_WARS Veteran Member
    2,021
    149
    Dec 19, 2008
    I heard of that being true. I wish I used the solid bushing before my swap.
    would have save me from swinging a hammer upwards while on my back:screwup: .. reverse lockout would have been the only thing to massage.:)
  3. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    Jon, so you going to help me install my T-56? ;)
  4. QUAKE_WARS
    2,021
    149
    Dec 19, 2008
    Im just a call away buddy!! Like I said before, call me for anything.:bowtie: Well, almost anything LOL.
  5. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    Yeeeeaaaahhhhhhhhhh....:D
    I am still not sure if I will go with a TKO600 or T-56 actually, although it will be one of the two since I want a manual. I really don't think I *NEED* a 6th gear, esp considering the ratios of the final gears for those two trannys are about the same. I know we talked about it and you gave me your opinion, but I am still not sure. :confused: Anyway, I digress...
  6. QUAKE_WARS
    2,021
    149
    Dec 19, 2008
    If you drove my car, you would be dead set on a t56 and you would never look back!!
  7. frankz
    frankz Veteran Member
    2,090
    13
    Aug 24, 2009
    Illinois
    What about the Keisler rs600 trans?
  8. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    I bet TKO owners would say the same thing ;)
    I am not saying I wouldn't enjoy driving a car with a T-56, but not sure I would *NEED* a T-56 versus a TKO600.
  9. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    I went to Lateral G and Pro Touring and read some about these trannys....interesting.
  10. QUAKE_WARS
    2,021
    149
    Dec 19, 2008
    if you start off with a kit your gonna pay BIG$$$$$$$
    or do a junkyard find complete like me for $1100.00 I have a
    friend who owns a HUGE junkyard :D
