Speaking of cowls
Discussion in 'Body Restoration' started by bigdav160, Jun 25, 2014.
  1. bigdav160
    bigdav160 Veteran Member
    592
    Jan 11, 2006
    Klein Texas
    What was the purpose of the two holes (one on each side) with the rubber plugs? I noticed the replacement cowl eliminates these holes.
  2. krabben1
    8,159
    44
    May 16, 2007
    ( . Y . )Delco
    Couldve been for drainage from the epoxy dip.
  3. 1971CamaroGuy
    3,763
    161
    Oct 31, 2004
    Mine weren't actually plugs but more like rubber grommets with a hole in it...I didn't bother putting them back when I installed my new cowl
  4. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    I agree, there are drain holes all over the car. Part of the body prep process.
