Spectra Premium EFI Fuel Tanks...NOW FOR 75-81 ?!?!
Discussion in 'High Tech Retrofits' started by trauschu, Jul 15, 2013.
  1. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    I think thats about right for the Ricks tank? correct?
    Tom
  2. Knuckle Dragger
    15,158
    1,626
    Nov 2, 2002
    Waddell AZ
    Nope I bought it all from them.
  3. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    Sure is. Like a lot folks, there were very little options in the past and had to do what needed to be done. IMHO, modding a stock tank is no comparison. It may have only cost a couple hundred dollars, but the tank will be missing an important feature...baffles. The $600 for the spectre would be money well spent and no labor time.
  4. ryeguy2006a
    ryeguy2006a Veteran Member
    157
    Sep 29, 2009
    Upstate, NY
    It isn't necessary to have baffles with the LS1 fuel pump assembly as it uses the venturi return system to keep the bucket full at all times. I haven't had one issue with fuel starvation, and I have been at less than 1/4 tank with some very hard launches.
  5. garyandcindy
    garyandcindy Veteran Member
    1,611
    Oct 20, 2004
    cumming,ga-usa
    Does anyone know what kinda hp the pumps in these can handle?
  6. sbca96
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    The replacement pump is is an AC Delco thats rated up to 450 hp. I dont know
    if the stock Spectra pump can. I have posted the flow info before.
    Tom
  7. Todd80Z28
    11,671
    308
    Jun 11, 2002
    Northern VA
    Amazon sells the 78-81 tank for $373 (plus free ship for Prime), 4-6 week lead time though-
    http://www.amazon.com/Spectra-Premium-GM201FI-Classic-Injection/dp/B00F4TTVIE/ref=sr_1_1?s=automotive&ie=UTF8&qid=1380726749&sr=1-1&keywords=GM201FI
    I may partake, but find the right AC Delco TBI pump to use with my carb/regulator setup. The original owner hogged out the filler neck to fit a regular/leaded pump nozzle more than 30 years ago, and I'm tired of listening to the old Carter electrical pump.:)
  8. SpeedAddict02
    SpeedAddict02 Veteran Member Lifetime Gold Member
    4,539
    Dec 31, 2002
    Wallkill, N.Y.
    That's a good deal imo.. I'm gonna save that link for Amazon.. just in case I find a decent 2nd gen.. lol
    This whole tank ordeal is what stopped me for going EFI when I had a 2nd gen.. Now, I'd gladly yank the LS1 out of my G body and drop it into a 2nd gen if I find one..:innocent:
  9. sbca96
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    Thats a really good price. I paid more than that for the early tank and then had
    to mod it and the car to work. But you do what you have too when there is not
    another option available.
    Tom
  10. Philip
    Philip Veteran Member Lifetime Gold Member
    1,807
    May 30, 2006
    Marana, AZ
    I am using a fuel pump for an 82 Corvette. It is rated at 14 psi, with that a Mr Gasket fuel pressure regulator part number 2015 for a return type system is also being used. Installed in June it is working great and is so quiet it is hard to hear it running with just the key on. A huge benefit is easy starts after the car has sat a few days. Pump fills the carb bowl in seconds, couple of pumps on the pedal to prime and set the choke and it fires right up. No more long cranking to get fuel to the carb.
