Speedo Drive / Driven Gears
Discussion in 'Transmission & Driveline Topics' started by 1981zapper, Sep 13, 2019.
  1. 1981zapper
    1981zapper Veteran Member
    1,400
    Apr 28, 2009
    Southern Ontario, Canada
    Since day 1 of owning the car, my speedo was never accurate, Originally my car came from the factory with 3.42 gears/ turbo 350 (non-lock up converter) Transmission and 225/70/15 tires (27.4" tall)
    my current set-up is;
    - 3.73 gears outback
    -Turbo 350 (non-lock up converter)
    - 275/40/17 Tires (25.7" tall
    Today I removed the Speedo bullet on the side of transmission and I have 22 Teeth on the driven gear, The Drive gear is greenish color any idea how many teeth it would be??
  2. Twisted_Metal
    27,172
    1,050
  3. 1981zapper
    1,400
    Apr 28, 2009
    so with a 9 Drive gear, I will need a 25 driven gear?
    current set-up is;
  4. Twisted_Metal
    27,172
    1,050
    Probably not.
    A 25 tooth driven gear requires a different diameter drive gear.:(
    Try calculating for your driven gear.
    If that doesn’t give you a workable combination, keep trying.
    https://www.tciauto.com/speedometer-gear-calculator
    You may need to change both gears or buy a speedometer ratio adapter.
    Several ways to accomplish the same thing here.
    Good Luck!
  5. tom3
    tom3 Veteran Member
    12,102
    367
    Aug 1, 1999
    ohio
    On the turbo trans changing the driver gear can be done without a lot of trouble. Several sites that will calculate the gears needed.
  6. 1981zapper
    1,400
    Apr 28, 2009
    i used an online calculator and a 25 driven and 9 drive gear will work for my combo
    now i need to find out if a 25 tooth and 9 tooth will mesh with each other
    https://www.summitracing.com/int/parts/oer-3860348/overview/
  7. Twisted_Metal
    27,172
    1,050
  8. cali cruzer
    cali cruzer Veteran Member
    2,808
    159
    Mar 24, 2002
    Henderson/Las Vegas, NV
    You could always look for a speedometer ratio reducer/adapter
  9. rchydzik
    840
    24
    Nov 13, 1999
    Colbert, WA USA
    You are looking for speedometer rpm of 1000 at 60 mph. So, with 27.4 inch tires, output shaft rpm at 60 is 2516. The speedo gears ratio that down to 1000.
    With 22 teeth driven, you need (1000rpm/2516rpm)*22teeth = 8.74teeth on the drive gear. You can vary each gear to get closer to round numbers.
    1000 rpm = 2516rpm*(drive gear / driven gear)
    8/20 would work well.
