Speedometer to slow
Discussion in 'Troubleshooting & Diagnosis' started by Uwe Koch, Apr 16, 2017.
  1. Uwe Koch
    Uwe Koch New Member
    13
    Oct 24, 2016
    79 Z28 the speedometer shows more then 20percent less then correct speed. Changed the gear driven from red to brown, now it is faster, but still much to slow, minimum 10 km/h, the more the faster the car is going. It is all factory setup, turbine wheels in 15 with 225/70 tires on, no modification in trans or rear end. Couldn't imagine the cable is the cause, could there be any internal problem in the speedometer unit? No more idea on my side, thanks for any comments, Uwe
  2. camarolife78
    camarolife78 Veteran Member
    546
    Jul 22, 2014
    Gardner, KS
    I might be wrong, but isn't the correct size tire like a 225/60R15? or 225/55R15? I run 255/55R15 on the back and my speedo is close, sounds like your tire might be too tall.
  3. Zspoiler
    Zspoiler Veteran Member
    3,265
    264
    May 6, 2012
    Federal Way, Washington
    The cable probably needs to be greased.
  4. cadillac_al
    cadillac_al Veteran Member
    841
    87
    Apr 22, 2015
    Maine
    How do you know it is original trans? Chances are it got replaced at some point and the speedo gears aren't correct. There are charts out there somewhere that show what speedo gears go with what axle ratio/tire size.
  5. 70-camaro
    70-camaro Veteran Member
    2,389
    440
    Mar 25, 2010
    marietta ohio
  6. Dave Nelson
    Dave Nelson Veteran Member
    4,399
    2,246
    Dec 19, 2003
    Vineland N.J USA
