spoungy brakes
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by newschool72, Feb 2, 2012.
  1. purpleflame
    purpleflame Veteran Member
    234
    May 7, 2003
    west valley, utah USA
    do you have a proportioning valve?
  2. newschool72
    newschool72 Veteran Member
    1,185
    Feb 25, 2011
    forsyth,ga
    Yea. the prop valve is the one the brake company said was right for my set-up.
  3. newschool72
    1,185
    Feb 25, 2011
    forsyth,ga
    Im not loosing any fluid that i can see and the master stays full.
  4. Cardinal
    8,278
    29
    Jun 22, 2003
    Endicott, NY
    Did you bench bleed the master cylinder? As odd as it sounds, the directions that came with your new master cylinder should have said to bench bleed it.
  5. frankz
    frankz Veteran Member
    2,090
    12
    Aug 24, 2009
    Illinois
    1/8" lines ?? The lines should be 3/16"
  6. newschool72
    1,185
    Feb 25, 2011
    forsyth,ga
    Do you think the 1/8" line could be my problem. It runs from a tee in the back to the braided steel lines at the caliper. It is not built like the factory set-up. Instead of the rubber line that runs from the main front to back brake line to the rearend, I built this one with a tee mounted above the driveshaft tunnel with a 1/8" line coming out both sides to bradied steel lines to the calipers. the 1/8" lines are run against the body with clamps and the braided line is the flex point for the rear to articulate. I built the system this way because i wanted the braided line for a firmer peddle and was having a heck of a time getting the line that goes from the main line to the rearend mount made of braided steel.
  7. frankz
    2,090
    12
    Aug 24, 2009
    Illinois
    Single piston and multi piston calipers have different volume requirements.Master cyl.size and line size should work in unison. Either way 1/8" is too small.
  8. purpleflame
    234
    May 7, 2003
    have you talked to the people you bought the brakes from usually they can tell you if all the components are compatible with each other, the 1/8 inch lines might just be the prob. as far as the master goes if it was leaking past the seals internally you would never know other than the feel of a spongy pedal.
  9. DEIVIONCRX
    DEIVIONCRX New Member
    27
    Nov 15, 2011
    Oklahoma
    I came up with this problem in my 80 T/A. New 1-1/8" master cylinder, new hard lines, stainless flex lines, rebuilt calipers front and rear, bench bled master cylinder twice, bled 3 small bottles of fluid through each wheel, pedal moves about 3" of travel then gets hard as a rock, car stops on a dime after the 3" of movement. Still haven't figured it out. I got the car with the rear brake lines capped and the pedal only moved maybe 1/2" and got firm, i hooked up the rear calipers and that's when i started having the travel problem.
    I'm betting on my problem being the portioning valve stuck since it had been bypassing the rear for who knows how many years before i got my car 7 months ago. But the only non new parts in my system are the Booster and Proportion valve.
  10. newschool72
    1,185
    Feb 25, 2011
    forsyth,ga
    I think i will pull the tee and a line and see if i can come up with some 3/16" line that will work . Its worth a shot and shouldnt be too expensive to try.
    As far as the company that i bought them from, Ive been back and forth with them over other (BIG) issues and i really dont have much faith in them. How much faith would you have in a brake company that didnt know first gen and second gen camaro's have different spindles, and that sold me a kit that caused me to have to send my spindles to them to be machined down to work?And sent me 5 on 5" rear rotors for the rear brakes? Im sorry , i didnt mean to rant and rave about how big a pain in the butt this brake system has been. Thanks for all your input guys. I will let you all know how the bigger brake lines work out.
