stall'n
Discussion in 'Competition Camaros' started by smallblock413, Sep 3, 2009.
  1. smallblock413
    smallblock413 Veteran Member
    817
    Mar 3, 2008
    reidsville
    my converter is a fairbanks [5000]....so i'm told...i know it is a fairbanks'97 converter...i called them to inquir about the stall speed[couple years back]...and was told that the part # i gave them was not a shelf item... custom cnvrt..anyways..the car pulls off normal[with a little stall]..not quite 1500..but can foot stall the car to 4200 before tires start to break im sure it would be higher with trans break set higher..[that was with the 388]..i know the torque of the motor plays a big roll in this...but a big block 496 what should initial stall be[guesstimate] 110 centerline sld/ roller cam/about 10.8/9 compression with a3800-4100 cnvrtr...?? just curious:cool:
  2. vegas1974z28
    4,563
    73
    Jan 10, 2002
    Las Vegas,NV
    I'll let you know in a couple of days :)
  3. quick79z
    quick79z Veteran Member
    392
    May 5, 2004
    saint john N.B canada
    we have a 496, 10.25;1, 660lbs tq 730 hp, 3000 lb datsun, it has a trans specialties 4200 and it stall around 6000
  4. Mwilson
    Mwilson Veteran Member
    My 3,500 +/- ACC converter flashed 4,100 with the 383 and 5,000 with the 408.
  5. jaywill
    jaywill Veteran Member
    1,048
    Sep 25, 2007
    REIDSVILLE,NC
    ....the more TQ the more stall...:) it's my car sb413 is talking about i didn't know if something was wrong......
    BTW: how many rpm did yours turn 2 get it to moving mine seams to b a bit much??? the stall is 3800-4100......
  6. vegas1974z28
    4,563
    73
    Jan 10, 2002
    Las Vegas,NV
    With my PTC 4500 it would stall to 5k in my old setup. We will see next weekend. I leave at 3000 on a two step though. car can't handle 5000 launch.
  7. jaywill
    1,048
    Sep 25, 2007
    REIDSVILLE,NC
    keep me posted...i'm not going to worry about i just don't want it to drive thru the converter on nos:whine:
  8. rustbucket79
    rustbucket79 Veteran Member
    There is never too much stall speed, only not enough peak engine RPM.
  9. rustbucket79
    Or to put it another (better) way, one of my customer's runs a 565 BBC that sees a 175 big shot kit from time to time. Stall speed (w/o 2 step activated) is 6200, there doesn't seem to be any operational issues. Shift point is in the 7500 area.
