Starter Heat Shield
Discussion in 'High Tech Retrofits' started by badazz81z28, Aug 4, 2019.
  1. badazz81z28
    16,172
    377
    Las Vegas, NV
    Anyone using a heat shield on their OEM LS starter? The heat is killing mine.
  2. Knuckle Dragger
    14,451
    1,102
    Nov 2, 2002
    Waddell AZ
    Factory shield, no problems with headers in AZ heat. Not a camaro.
  3. GDSmith
    GDSmith Veteran Member
    104
    19
    Aug 4, 2012
    Glen Ellyn, IL
    I also have a 65 GTO which is notorious for hot starters. Went to one of the bid box home improvement stores and purchased a piece of flat copper sheet, bent, beat and banged into shape to cover the starter. NEVER have had a problem since.
