Starter Woes
Discussion in 'High Performance Modifications' started by vegas1974z28, Jan 14, 2019.
  1. vegas1974z28
    4,628
    98
    Jan 10, 2002
    Las Vegas,NV
    I have had starter issues for probably 10 years..... I get starter kickback and have broken starters and flexplates. I am in need of some nastyz help.......
    Assuming the starter is aligned properly ...... What could be the cause of this? I'm at my wits end.....
    Car has dual batteries
    I can spin it before I hit the ignition and still get kickback
    timing at 36 locked (has a msd box with start retard)
    HELP.
  2. CorkyE
    9,885
    321
    Got me, kickback with ignition off. Do you have the cam retarded from C/L? On the old gas powered 2 1/2 & 5 ton Army trucks, we hit the starter before turning ignition on because they were bad to hydro lock from gasoline running through the carburetor.
  3. vegas1974z28
    4,628
    98
    Jan 10, 2002
    Las Vegas,NV
    SEEEEEE I swear it gets hydro locked......After sitting for an hour or so, it kicks back......when hot USUALLY not.
    1980RS likes this.
  4. 80NastyZ
    80NastyZ Veteran Member
    136
    Feb 8, 2007
    Poconos P.A.
    Any way you could drop in a simple HEI distributor to rule out the ignition system ? If it's predictable that should rule out ignition. Not saying race with it in there , just use to test.
    Last one I fought turned out to be an older Crane box with a start retard that wasn't doing what it was supposed to . Same deal as yours , BBC, locked @ 38* , Good starter , Billet flexplate , but there was no rhyme of reason to the kickback. Removed the locked out distributor , installed an HEI unit locked at the same timing and no more kickback.
    Just a thought .
    TOM
  5. 1980RS
    1980RS Veteran Member
    2,499
    235
    Jun 17, 2006
    MN
    Here is what I did when having starter troubles. I ordered a new PM starter aka: vortec from DB Electrical, then I got the new flat flexplate from PRW and it solved all my problems.
  6. vegas1974z28
    4,628
    98
    Jan 10, 2002
    Las Vegas,NV
    Well i'm halfway there .......saturday installed a NEW PRW flexplate........maybe I should bite the bullet and get a new starter too....Maybe all the kickbacks have killed that starter....
  7. cadillac_al
    cadillac_al Veteran Member
    705
    50
    Apr 22, 2015
    Maine
    Maybe the start retard isn't working?
  8. muscl car
    21,269
    453
    Jul 8, 2001
    High Desert of Hesperia Calif
    That sucks Mattie !!!!
    Can't believe you're still having starter issues , I remember a few years ago when I met up with you at a PSCA race at Fontana and you were having starter problems
    Wasn't it that time the starter was dragging not turning the motor over fast enough ???
  9. SRGN
    SRGN Veteran Member
    615
    197
    Feb 20, 2009
    Central NJ
    Pull the plugs after a hot soak. Crank it and see if any coolant comes out of the holes.
    muscl car likes this.
  10. muscl car
    21,269
    453
    Jul 8, 2001
