1. Its_not_a_transam
    Its_not_a_transam Member
    43
    Mar 23, 2019
    I have an 80 z. Steering box is leaking and a little sloppy. i Would like some advise on the best replacement box or a ratio that is better than the stock box. The iroc box is a good one i hear.
  2. 79T/Aman
    79T/Aman Veteran Member NastyZ28 Sponsor NazstyZ28 Sponsor Lifetime Gold Member
    2,487
    146
    Oct 7, 2004
    Dickson TN.
    670 box is best, the 3rd gen box is still an 800 box
    Its_not_a_transam likes this.
  3. Its_not_a_transam
    43
    Mar 23, 2019
    Do they require different fittings and or hoses?
  4. dave@ztech
    3,399
    703
    Mar 27, 2016
    NY
    They require different fitting, if yours are still the flair instead of the metric o ring fitting, they sell the adapters that fit on the end of your existing hoses , if needed
  5. UMI Tech
    UMI Tech Member NazstyZ28 Sponsor
    51
    28
    Jan 10, 2017
    Central PA
    We have a Turn One 670 gear on our '71 Camaro.
    8:1 ratio for autocross. For general street use the 12.7:1 is extremely popular.
    As mentioned by dave above, they take the metric o-ring fittings from the factory. With the adapters you can use your "SAE" hoses. For race stuff we convert to the -6 lines.
    ramey
  6. Twisted_Metal
    26,948
    928
    An 80 Z would already have the metric fittings from the factory. (80-81 switched to Metric O-ring fittings.)
    (I discovered that when I attempted to swap the PS pump/lines from my 78 into my 80.)
    In other words... A 3rd gen IROC box or the 670 box should work with your current hose fittings if they are still the factory pieces.
