steering column bearings
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 75Maro, Feb 7, 2019.
  1. 75Maro
    75Maro Veteran Member
    348
    11
    Mar 31, 2008
    Dallas,Tx
    tore down my steering column to replace bearings upper and lower.
    Cant find any threads on this can someone help out.
  2. Green hornet
    Green hornet Veteran Member
    1,616
    263
    Oct 11, 2015
    North Bay, CA
    I just rebuilt a tilt column for mine. Cleaned all the bearings and greased them. I’m not sure what inform you are looking for.
  3. 75Maro
    348
    11
    Mar 31, 2008
    Dallas,Tx
    can the bearings be sourced for replacement
  4. Green hornet
    1,616
    263
    Oct 11, 2015
    North Bay, CA
    Yes I found them on various sites when doing a search. I just cleaned mine up and re-greased theme. Here is a heads up on the lower bearing. I ordered a new one from a reproduction site (to remain nameless) the bearing snaps into a plastic piece that then fits into the very bottom of the column. It is held in place with a snap ring. Well the Bearing does not fit tite in the plastic piece allowing the entire bearing assembly to rotate. I ended up cleaning the old one and regressing it. Hope this helps.
  5. 75Maro
    348
    11
    Mar 31, 2008
    Dallas,Tx
    I picked up the crown auto unit from Summit. Hopefully it fits and doesn't spin cause my lower bearing was completely shot. A few ball bearings had already fallen out. How about the upper bearing?
  6. Green hornet
    1,616
    263
    Oct 11, 2015
    North Bay, CA
    There are a few different ones. Just search gm steering column bearings
  7. Zspoiler
    Zspoiler Veteran Member
    2,951
    198
    May 6, 2012
    Federal Way, Washington
    Do you have a bearing shop nearby ? Like Brown Bearing.Or maybe Chevrolet
  8. 75Maro
    348
    11
    Mar 31, 2008
    Dallas,Tx
    There’s a Pervis about 10 minutes away from me. I’ll check with them
  9. camaro71/holland
    1,109
    49
    Aug 27, 2003
    The Netherlands
  10. 75Maro
    348
    11
    Mar 31, 2008
    Dallas,Tx
    Thanks I just installed this exact bearing this morning. I’m trying to locate the upper bearing now. Any info on it?
