Steering shaft upgrade?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Scottyd, Nov 27, 2018.
  1. 1971CamaroGuy
    3,764
    161
    Oct 31, 2004
    The only thing that keeps me from going full U-joint is the fact you'll get more vibrations being transfered into the steering wheel...it's bad enough with solid bushings and such.
  2. MP81
    MP81 Veteran Member
    307
    9
    Oct 10, 2016
    Washington Township, MI
    It hardly added any more. The Borgeson lower U-Joint is isolated.
  3. ULTM8Z
    ULTM8Z Veteran Member
    9,208
    365
    May 19, 2000
    Los Angeles
    you will not notice any increase in vibration. like MP81 said, the lower one is a dampening joint, not a solid ujoint
  4. Z28 Mark
    Z28 Mark Veteran Member
    216
    Feb 14, 2001
    San Jose, CA.
    I just started the Borgenson u-joint and shaft today but my steering box has a leak at the spline shaft. Going to take in in tomorrow and see if I can get it worked on.
  5. CaliCamaro75
    CaliCamaro75 Veteran Member
    429
    31
    Sep 6, 2015
    Winchester,CA
    Can someone post the link for the borgerson build. I'm not seeing it. Thanks
  6. ULTM8Z
    9,208
    365
    May 19, 2000
    Los Angeles
