Still can't decide 60103 or 60104???
Discussion in 'Engine Topic' started by meangreen73, Nov 4, 2009.
  1. meangreen73
    meangreen73 Veteran Member
    719
    Feb 16, 2008
    Pittsburgh
    I'm still trying to pick a cam for my 80. I'm down to 2 cams the lunati voodoo 60103 and 60104. I just cant decide.:confused: lol Which one do u think I should use? I have a 350 with canfield aluminum heads (195cc runners, 202 valves, and 64cc chambers), edelbrock performer manifold, edelbrock 600cfm carb, hooker super comp headers, th350 trans, 3:42 gears, and Im probley gonna use around a 2800 stall converter. My cars a driver that will occasionally see a little track time. I don't wanna get horrible gas mileage but i wanna get the most out of my motor. I'm kinda leanin toward the 60104 but idk if that will be to big for my application? What do u guys think? thanks
    60103
    http://www.summitracing.com/parts/LUN-60103/
    60104
    http://www.summitracing.com/parts/LUN-60104/
  2. cmonson
    cmonson Veteran Member Gold Member
    4,134
    Apr 7, 2006
    Calgary, Alberta
    what is your compression ratio?
  3. meangreen73
    719
    Feb 16, 2008
    Pittsburgh
    Im not sure. i dont have the motor together yet. if i had to guess id say around 10 to 1? It has stock 350 pistons and 64cc combustion chambers.
  4. kenny77
    kenny77 Veteran Member Lifetime Gold Member
    2,681
    Jul 31, 2001
    Ft. Lauderdale, FL
    Alrighty then......I have a 383 flat top ,high lift Vortecs, 10.5 to 1, 4 speed 3:73 UDHarold told me to go with the Voodoo 104...I wimped out and went with the 103. This cam idles at like 14-15 in of vacuum, notice the idle but not choppy or anything...I should have went with the 104, AND still might change it. I say do the 104.>>>>>>>>>>>>>>>>Ken
    If you do have the stock dish pistons in there you are at 9.3 or 9.5 to 1...and that means use the #103 Voodoo.
  5. meangreen73
    719
    Feb 16, 2008
    Pittsburgh
    yeah there stock, as far as i know, I havent pulled a head yet. Im not real good at guessing compression. lol So go with the 103 then?
  6. Todd80Z28
    10,806
    Jun 11, 2002
    Northern VA
    Go smaller. You won't miss the 10hp, but if you go too big, you'll miss the driving manners of the smaller cam.
  7. meangreen73
    719
    Feb 16, 2008
    Pittsburgh
    Yeah never really thought about it that way. I'm gonna go with the 60103
  8. Louich
    Louich Veteran Member
    2,412
    Mar 8, 2004
    Arthur, Ontario
    maybe Ken will sell you his now :):)
  9. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    It's NOT SOTA and certainly NOT a UDHarold cam, but, imho, the old Isky 264 Mega is made for a 9.3 to 9.5 CR. engine!
    It will be powerful!
    You get her up to 10 to 1 CR., then install a 268 VooDoo!
    pdq67
    PS., and I'm a UDHarold fan!
  10. earnhardtgm3
    earnhardtgm3 Veteran Member
    1,431
    Dec 18, 2007
    Camaro Country,GA
    I use the lunati voodoo 60103 in my 79Z and it hauls azz.I had to go with a 750 carb for the upper RPM's.
    Product Description
    http://www.lunatipower.com/Product.aspx?id=1984&gid=287
    Lunati's Voodoo series of Hydraulic camshafts deliver more area under the curve than any other series of Hydraulic camshafts. This means more throttle response, quicker acceleration, more vacuum, better efficiency, combined with maximum horsepower and torque!Hydraulic. The most awesome 268 cam ever produced! Out-powers all others! This High Performance street cam likes 2400 RPM stall, 700 cfm carb, dual plane intake and headers. Makes un-equaled power to 6200 RPM with proper valve springs. If you're looking for a Very Strong cam with great street manners then this cam is it.
    * Advertised Duration (Int/Exh): 268/276
    * Duration @ .050 (Int/Exh): 227/233
    * Gross Valve Lift (Int/Exh): .489/.504
    * LSA/ICL: 110/106
    * Valve Lash (Int/Exh): Hyd/Hyd
    * RPM Range: 1800-6200
