Stock 1981 Z28 Carb Noise
Discussion in 'Troubleshooting & Diagnosis' started by La.Z8, Nov 30, 2019.
  1. La.Z8
    La.Z8 Veteran Member Lifetime Gold Member
    502
    23
    Jan 6, 2003
    N.W. Louisiana
    I recently picked up a pretty nice bone stock 81 Z28. It still has the Air pump, catalytic convertor, etc. The Camaro has a noise from the Carb, its like a ticking sound. I remember vaguely, but it`s been a while since I`ve been around this era of GM stock gas engines, is that a normal sound? I`m aware that this model is the 1st to have the fuel and ignition somewhat computer controlled. I really don`t want to modify the car as it`s only got 81K on the clock. Normally years ago I would have trashed the intake/carb combo and just move on. But now I would rather keep it original. Thoughts ?? Thanks Dale
  2. grzewnicki
    3,428
    161
    Dec 9, 2009
    Gordon from Jacksonville Fl
    Does it have an electrical connection on it (closed loop is what the info on autozone says for stock carb, 02 sensor feedback), it is a solenoid, not sure what it does but could you put your finger on the electrical connection and see if you can feel anything that lines up with the ticking noise. I seem to recal my 1982 S-10 with the 2.8 V6 had a similar carb with one connection on it and I believe I recall it ticking also. I thought of that immediately when I read your post.
  3. Vettenick
    Vettenick Vettenick
    99
    18
    Jul 17, 2019
    That is a mixture control solenoid. The sound is the solenoid moving the metering rods in the jets to control air fuel ratio.
    The sound is normal.
  4. La.Z8
    502
    23
    Jan 6, 2003
    N.W. Louisiana
    Grzewnicki, I actually haven`t yet taken the air cleaner assembly off to check, but will. I`ve been occupied with travel/work and the holidays. Vettenick, now that you mention it I recall a friend had an early 80`s Silverado that had the same carb sound. Still weird though. Thanks for the replies !!
  5. RickM
    RickM Veteran Member
    478
    44
    Apr 16, 2004
    Gaithersburg, MD
    This ^
    I have an 81 also.
    RickM
