stock lq4 550 rwhp?
Discussion in 'High Tech Retrofits' started by griffsbombelco, Feb 17, 2012.
  1. griffsbombelco
    griffsbombelco Veteran Member
    220
    Aug 17, 2009
    socal
    The day has finally come, dyno day in the am hopefully all goes well I would really like to make 550 hp my setup is
    stock 6.0 ls lq4
    04 ls6 cam
    ls9 head gaskets
    arp head bolts
    60 lb inj
    borg s475 turbo
    stock exhaust mani's
    stock intake
    stock tb
    th400 trans
    10 bolt
    planning on running about 14#s of boost
  2. My73LT
    My73LT Veteran Member
    1,540
    May 29, 2001
    Orlando, Fla
    Sweet, this is about the combo I keep thinking about dropping in my heap.
    My guess is you'll beat that 550 RWHP.
    Let us know how it turns out.
  3. ErikNORCAL
    ErikNORCAL Veteran Member
    1,132
    11
    Aug 6, 2003
    now in VA
    bad ass
  4. Todd80Z28
    11,569
    245
    Jun 11, 2002
    Northern VA
    At first, I was thinking- "Dream on, I mean LS engines are good, but 550rwhp from a 6.0. Let's be realistic." And then I saw the hair dryer...:)
    Good luck, let us know.
  5. JONESYFXR
    JONESYFXR Veteran Member
    2,177
    Oct 10, 2009
    BUFFALO, NY
    Dude......AWESOME!!!
    Come on....we're dying to know!!!!!
  6. camcojb
    camcojb Veteran Member Lifetime Gold Member
    2,599
    Jan 10, 2000
    Wilton, Ca. USA
    What fuel are you running? Do you plan on water/alky injection? How much timing is in your tune? 14 psi on 10:1 compression with 91 octane should be interesting long term............. ;)
  7. streetmachine
    streetmachine Member
    40
    Feb 12, 2012
    DET, MI
    The LQ4 is the perfect stock block to turbo with 9.4 compression, not 10:1. Im doing a LQ4 with L92 heads and LS3 intake, and a 76mm turbo. Good luck on the dyno, interested in the results :)
  8. DoTheDew
    DoTheDew Veteran Member
    899
    Mar 2, 2010
    Leduc, Alberta
    Looks Good. Let us know how it goes. Little concerned with the upper rad hose though. What hood are you running for clearance?
  9. camcojb
    2,599
    Jan 10, 2000
    Wilton, Ca. USA
    read it as an LQ9 which is just over 10:1.............. :confused:
  10. LSXZ28
    LSXZ28 Veteran Member
    552
    Jul 17, 2009
    Crofton, MD
    You will make your number! :cool:
