stock lq4 550 rwhp?
Discussion in 'High Tech Retrofits' started by griffsbombelco, Feb 17, 2012.
  1. My73LT
    My73LT Veteran Member
    1,540
    May 29, 2001
    Orlando, Fla
    I am jones-ing bad ! Killing me to know what numbers you got...
  2. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    You're the 2nd guy with a 2nd gen I've seen get that Vortec truck intake to fit.
    What did you your hood to get that truck intake to fit ??
    What engine mounts and frame mounts did you use???
    Looks cool, good luck!!!
  3. Todd80Z28
    11,387
    176
    Jun 11, 2002
    Northern VA
    Top pic= little hood springs=fiberglass cowl hood. That's my guess.
    What were the numbers?
  4. usmcz28
    usmcz28 Veteran Member Lifetime Gold Member
    382
    Jun 19, 2005
    Rochester, NY United States
    I have all that minus the turbo, I did get a custom cam ground though so who knows. I'd like to see how yours does with the LS3 top end on it.
  5. Protour-Camaro
    Protour-Camaro Veteran Member
    2,111
    Feb 16, 2012
    California
    Couldnt you have got 550hp without a turbo?
  6. 1970camaroRS
    1970camaroRS Veteran Member
    2,606
    Mar 4, 2001
    Everett, WA
    550 crank hp = easy with an lq4 and ported heads
    550 wheel hp = pretty much impossible. Heck, even 500 wheel hp is nearly impossible with 364 cubes and low compression.
    He is talking wheel hp.
  7. muscl car
    21,492
    551
    Jul 8, 2001
    High Desert of Hesperia Calif
    is this the car you replaced your 10 second sbc 240z with and are you going to run PSCA with the new combo ??
  8. muscl car
    21,492
    551
    Jul 8, 2001
    guys this is going to be a 1/4 mile car only running at fontana or @ irwindale
  9. 69CHVL
    69CHVL Veteran Member
    175
    Sep 6, 2006
    THORNTON, PA (NEAR PHILLY)
    Guess it blew up!
  10. griffsbombelco
    griffsbombelco Veteran Member
    220
    Aug 17, 2009
    socal
    sorry guys for the delay first trip to the dyno had issues!!! took a week to work over the problems and found it. I ordered a 10 micron pre pump filter and was starving my pump badly. I replaced it with the correct 100 micron and boy did the car respond
    Car made 623hp to the wheels and 590tq
    for the people who said I wouldn't happen eat your hearts out!!!
    [​IMG][/IMG]
    http://youtu.be/z_RJPgW1WEM<iframe width="480" height="360" src="http://www.youtube.com/embed/z_RJPgW1WEM" frameborder="0" allowfullscreen></iframe>
