stock lq4 550 rwhp?
Discussion in 'High Tech Retrofits' started by griffsbombelco, Feb 17, 2012.
  1. Rene Melten
    Rene Melten Veteran Member Lifetime Gold Member
    4,063
    Sep 22, 2007
    Blind Bay, B.C.
    :eek: Holy Cow. I had to see this for my self so I fixed it for you.
    [youtube]z_RJPgW1WEM[/youtube]
  2. griffsbombelco
    griffsbombelco Veteran Member
    220
    Aug 17, 2009
    socal
    haha thanks I was just reading how to fix it
  3. muscl car
    21,585
    584
    Jul 8, 2001
    High Desert of Hesperia Calif
    623rwhp is definately going to put that camaro into the low 9's high 8 seconds in the 1/4 to bad the only tracks are LVMS or famosa since irwindale and fontana are closed
  4. griffsbombelco
    220
    Aug 17, 2009
    socal
    Are track situation in socal is ridiculous!!!
  5. muscl car
    21,585
    584
    Jul 8, 2001
    yep the track situation in socal sucks !!!!:mad::mad: ,can't even play on 135th and main anymore either !!!:mad:
    with that much hp at the wheels you'll need a chassis cert and a 25.5 cage installed in order to run down the track ,like i mentioned you're looking at a high 8 second to low 9 second pass at well over 160mph
  6. My73LT
    My73LT Veteran Member
    1,540
    May 29, 2001
    Orlando, Fla
    I am very impressd. Awesome job.
    Whats that work out to at the crank ? 730+ hp ?
  7. 69CHVL
    69CHVL Veteran Member
    175
    Sep 6, 2006
    THORNTON, PA (NEAR PHILLY)
    Awesome!!
    Building a s475/LQ4 myself, all stock except for a XR269 216/220 114lsa cam, and the Holley EFI system, truck intake.
    How much boost did you end-up with, and what rpms were the hp/tq? What does your fuel sys look like?
  8. griffsbombelco
    220
    Aug 17, 2009
    socal
    that was 15lbs 91oct low boost and 100oct at 15lbs the fuel system stock tank sumped a1000 pump stock rail, regulator to the stock feed in the tank as a return it was a pretty low budget setup
  9. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    FYI, both Lompoc and Santa Maria are in process of 'building' tracks, and thats
    including road courses as well. Lompoc will be an 1/8 mile and SM a 1/4 mile. I
    dont know the details of the planned road courses.
    This would bring sanctioned drag racing back to the County that it originated in.
    Goleta, California was the location of the first official drag racing, at the Santa
    Barbara Airport (a converted World II War Air Field) in Goleta. Both Lompoc and
    Santa Maria are in Santa Barbara County. Keep your fingers crossed guys/girls.
    Tom
  10. 69CHVL
    175
    Sep 6, 2006
    Perfect, as I'm trying to reuse the stock reg myself. What map sensor did yo use?
