Stock LS2 Thermostat input please
Discussion in 'High Tech Retrofits' started by GDSmith, Mar 4, 2020.
  1. GDSmith
    GDSmith Veteran Member
    150
    26
    Aug 4, 2012
    Glen Ellyn, IL
    hello all,
    Looking for input regarding thermostat selection for stock LS2. A lot of noise out there, looking for input based on your experience.
    Thanks in advance
  2. badazz81z28
    17,396
    604
    Alabama
    My input, there is too much input for such a small decision. Just go to Autozone and buy a stock replacement. Why is it more complicated than that?
  3. ErikNORCAL
    ErikNORCAL Veteran Member
    1,141
    12
    Aug 6, 2003
    now in VA
    If I remember correctly, the factory temp settings are pretty high on the LS2, at least the fan activation temps.
  4. badazz81z28
    17,396
    604
    Alabama
    Stock is like 195. If you decide to swap it out for a 180 or even a 160, you'll need to change the fan temp setting too.
  5. CorkyE
    10,536
    548
  6. ErikNORCAL
    1,141
    12
    Aug 6, 2003
    now in VA
    Pretty sure stock Tstat is 186F. Having run a 2005 Ls2 drivetrain, The factory fan activation settings were up there, especially the high.
