Stock tank modification for EFI...
Discussion in 'High Tech Retrofits' started by Ca-ma-ro, May 2, 2009.
  1. JJFarmer
    JJFarmer Veteran Member
    2,447
    Jun 28, 2002
    Lenoir City, TN
    Seeing how I'm in the fuel tank stage, bumping this up...great thread
  2. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Ewwwww.........now this is interesting.
    So now I have 2 options instead of buying a new tank and sending it out. :eek:
    I'm going to PM a Moderator to Sticky this thread. :)
  3. SupplySgt
    SupplySgt Veteran Member Lifetime Gold Member
    1,374
    Jun 20, 2009
    Finally back home!!!
    This definitely needs to be stickied. cause this is something I could do when I drop an L67 into a 2nd gen
  4. usmcz28
    usmcz28 Veteran Member Lifetime Gold Member
    382
    Jun 19, 2005
    Rochester, NY United States
    Any updates on how/if this is running with the new tank?
  5. onelapduster
    onelapduster Veteran Member
    720
    May 5, 2010
    South Joursey
    how are the fuel pump electrical connectors holding up?
  6. onelapduster
    720
    May 5, 2010
    South Joursey
  7. Kricka
    Kricka Veteran Member Lifetime Gold Member
    419
    Sep 26, 2002
    Skellefte. SWEDEN
    Thanks for sharing. I am going to buy it to.
  8. jerhofer
    jerhofer Veteran Member
    490
    Jun 4, 2009
    Rockwell, NC
    I installed the FAST EZ-EFI in my car this past winter and did not change or modify my tank. When I installed the tank about a year ago, I did install a McRobb billet fuel sender with both a feed and return line input. While running carburetion, I simply plugged the return line input.
    During the fuel injection install, I hooked up my existing fuel line to the return side of the sender and ran a new line for the feed line to the frame mounted fuel pump. I have had absolutely no fuel feed issues. And I have run the tank down below 1/4 just to see what would happen.
    http://www.robbmcperformance.com/products/1079_gmsend.html
    Here is a link to the fuel injection install.
    http://jerryforthofer.wordpress.com/2010/12/11/installed-ez-efi-in-my-1977-camaro/
  9. jerhofer
    490
    Jun 4, 2009
    Rockwell, NC
    Update
    UPDATE
    I finished my LS1 install last week and used the same fuel sytem described above. Absolutely no issues. I ran the tank down to below a quarter tank again just to see what would happen and it still worked fine.
  10. arick793
    arick793 Veteran Member
    1,127
    Oct 27, 2008
    Rochester, NY
    A couple of concerns;
    Do you think the vibration of the fuel pump would eventually make the solder holding the tube to the sending unit break?
    And is the electrical connector for the fuel pump completely submersed in gas? That would make me a little uneasy
