stock valve springs
Discussion in 'Engine Topic' started by shanep91, Nov 9, 2009.
  1. shanep91
    shanep91 Member
    50
    Oct 8, 2009
    davenport iowa
  2. doc221978
    doc221978 Veteran Member
    355
    Nov 29, 2008
    Allenhurst, GA.
    Not only will the stock springs fail immediately...... if it is a stock engine it will too. Cams like that need more compression, higher flowing heads, and if you rev to 7k rpm's it needs a bullet-proof bottom end. You need to match all the components together to get the most out of it.
    That would be hell to drive on the street too. For a flat tappet cam, I wouldn't go above around a 268 or 272 cam. For a roller, I am happy with my xr 282. That 282 is a little rough on the street.
  3. CorkyE
    10,536
    548
    Either of those cams would be a waste on a stock head/spring combo. Even the best flowing vortec heads will need worked for those cams.
    Like Doc said, you will need to match your entire engine combo to realize any gains from those cams.
    You don't have much posted in your siggy. What do you have, what are your intentions, and most important; what is your budget? It's all got to work together.
  4. shanep91
    shanep91 Member
    50
    Oct 8, 2009
    davenport iowa
    its a 1990 chevy 350 with stock bore but has flat top pistons and the heads have 202 160 valves in them, they are shaved down, i think ill have about 10:1 compression, the heads are heavily ported too
  5. 1BAD78
    1BAD78 Veteran Member Gold Member
    814
    Apr 12, 2007
    Broken Arrow Ok
    not only would the stock spings break.they would probably bind and flatten the lobes.i had a crane 266 break every damn valve spring in a stock head i used back in the day and it only had like .440 lift.and really that is way too much cam for a pretty much stock short block.
  6. z28rod
    z28rod Veteran Member
    4,472
    Apr 30, 2009
    hopewell junction,ny
    stock springs are good to .480 lift , z28 springs are good to .500 lift.
  7. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    "I had a crane 266 break every damn valve spring in a stock head i used back in the day and it only had like .440 lift and really that is way too much cam for a pretty much stock short block."
    Calling BS here b/c the Crane 266/266 Energizer is a dandy 2-up from stock cam imho.
    Something wasn't right??? Hell, -929 hy-cam stock springs, ALTHO QC'd, were used on the old 30-30 solid lifter cam so I don't buy it!
    And right, match your CR w/ your cam and if you want more help, then post back your CR, (OR YOUR ENGINE COMBINATION), and we will be all over this like flies on sh*t!!
    Head chamber cc, headgasket thickness, piston type, DITH piston depth, etc., etc...
    At least I will be.......
    pdq67
  8. rustbucket79
    rustbucket79 Veteran Member
    9,076
    May 29, 2003
    British Columbia, Canada
    Spring bind and seal to retainer clearance is a big concern on any engine (must be checked) but flat top pistons and 2.02 intake valve requires an extra level of inspection since there are several cast flat top pistons out there that give questionable radial clearance with the larger diameter intake valve.
    Stock "tall" small block springs will take a suprizing amount of cam lift, but won't give nearly the control required for a performance cam, which is why pretty much "ANY" performance cam lists the required springs.
  9. Simon@London
    Simon@London Veteran Member
    1,244
    Feb 16, 2009
    London Ontario
    I just found out what the wrong springs do to a motor. This Hotcam was great on old vortec heads until you went past 5,100 then things got wonky.
    I soon found rockers making noise with some messed up internals after revving it past 5500 a couple of times. That was with stock vortec springs so now I went with screw in studs & Bee Hives and it's very smooth up in the upper rpm zone now.
  10. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    Oh, and btw, I ran my stock 350SS engines -929 cam springs w/ my 1200 miles from new installed -151 cam w/ .447" lift for years as my DD.
    Took her up above 6,000 rpm many times.
    pdq67
