STOP THE PRESSES, need opinions.
Discussion in 'High Tech Retrofits' started by Aceshigh, Jan 19, 2006.
  1. driftwood
    driftwood Veteran Member
    2,026
    Mar 4, 2002
    07882, NJ
    With a little search I came up with this info to bolt your 700r4 to the LSx.
    http://www.advanceadapters.com/catalog/073.html
    Of course,I do not know if the plate is SFI rated,but the price seems right.
  2. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Ah....thanks much guys. i will check into this stuff now.
    I might be buying a complete LS1 + 4L60 if I get the right price. We shall see in 3 days how the bidding goes.
  3. camcojb
    camcojb Veteran Member Lifetime Gold Member
    2,599
    Jan 10, 2000
    Wilton, Ca. USA
    The GTO oil pan won't work. Other than that it should fit. I can take pics of accessory setup from my LS2 as the front clip is off my car for the twin turbo install. The LS2's used a 4L65E which is a bit stronger than the 60E; I thought the LS1's did also.
    Jody
  4. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Thanks Jody.
    Hey, can you look at this and tell me if it's what I need ???
    There's 2 additional components that I'm not familiar with, and he's giving the gas pedals too. I thought you only needed the pedals if it was a drive by computer system. I talked to the guy and he said they're sellin the pedals too only because of hot rodders building from scratch.
    1.) BOSCH THROTTLE POSITION CONTROLLER:
    GM 1028 2710 , 0 265 108 031
    2.)POWER TRAIN INTERFACE MODULE : 92123173 , 011909
