Stuck between cylinder heads
Discussion in 'High Performance Modifications' started by Justin79maro, Sep 11, 2019.
  1. Justin79maro
    Justin79maro Veteran Member
    140
    Jan 15, 2015
    Bonne terre, missouri
    I’m wanting to go aluminum heads now on my 385 stroker. But I’m not sure which ones will give me the kinda power I’m looking for. First I’m wanting power in the low end to mid range max of 6000rpm. It’s a street strip car too, 1/8th mile only. My cam specs are 230/236 duration .545/.555 lift Hyd roller. motown single plane intake, 10.1:1 compression with 64cc heads I currently have. 3.42 3k stall, I’m trying to make around 500-530hp and roughly the same tq if possible, I will not be changing the cam in this, so which head would you guys choose for the job? I’ve narrowed it down to 2 heads , the AFR 195cc eliminator street and the Pro-filer 210cc. Which of those would YOU pick if the price wasn’t an issue? And if you need more engine or car specs ask or check my sig. thanks ahead!
    1980RS likes this.
  2. 1980RS
    1980RS Veteran Member
    3,152
    507
    Jun 17, 2006
    MN
    I would go the AFR 195's smaller runner will be better on the street. Mt pump gas 358 was in the mid 11's @116 with some home ported 180cc Bowtie heads for what it's worth.
  3. GoldenOne7710
    4,739
    365
    Jun 23, 2004
    Athens, GA
    If money isn't a factor, AFR all day long.
  4. 79RedZ
    79RedZ Veteran Member
    682
    37
    Mar 24, 2009
    Hamilton,MI
    AFR. Got to watch a 383 with the AFR 195's, with a similar cam and compression to yours, make 520 hp on an engine dyno. And this was with a performer RPM airgap intake.
  5. Justin79maro
    140
    Jan 15, 2015
    That’d be perfect, do you remember the tq peak rpm and the hp peak rpm?
  6. biker
    biker Veteran Member
    763
    55
    Dec 7, 2014
    New Liskeard Ontario Canada
    My 383 works great with ATK 195 heads. I believe I'm close to 500 hp, with a small bit less cam than you. ATK heads are profilers with a stock location exhaust port. Quality on them is great, but after reading what everyone here constantly says about AFR, if money is not a consideration, go AFR.
  7. Lowend
    14,932
    429
    Mar 25, 1999
    San Jose, CA, USA
    If money isn't an issue than go straight to the AFR 210cc
    They will crush any other conventional small-block head on the market. Don't be afraid of the 210cc runner, with a modern head design it will be just fine on your 383
  8. G72Zed
    G72Zed Veteran Member
    1,018
    216
    Sep 8, 2015
    Reading into the specs you provided, and assuming a 3750lbs starting line weight, your at approx. 400 rwhp and 450-460 at the flywheel, give or take. Are these the "platinum" series of head castings, if not, have they been ported at all.
    I believe there is enough potential in those heads to hit your 500-530 hp goal without a problem. Just saying.
  9. Justin79maro
    140
    Jan 15, 2015
    That time is with vortec heads that I had one before the dart iron eagle, with the darts it only ran a 7.9x @88 with a 1.85 60’. Heads are just standard dart iron eagle 200cc, nothin has been done to them. I was in a bind when swapping them on at the time or I would have went with aluminum then
    1980RS likes this.
  10. Rdobbs1977
    Rdobbs1977 Huge Guns N Roses Fan
    309
    15
    Dec 1, 2014
    Nashville
    Profiler, LMAO. Love their specs, love their price. Good luck trying to buy a pair. Don't care if you try to go direct thru them or go thru a major vendor/supplier--you'll be waiting an eternity. I'm building a motor similar to yours, will throw out the Brodix IK heads as a third option for ya. Watch that SCR if this is a street/strip car. The internet and others will tell you 10:5:1 and can run pump gas. Me, keeping it at the 10:0 mark is optimal if you want to run pump.
