Stuck between cylinder heads
Discussion in 'High Performance Modifications' started by Justin79maro, Sep 11, 2019.
  1. G72Zed
    G72Zed Veteran Member
    1,080
    235
    Sep 8, 2015
    X2^^ Well said, That's why some people are disappointed in their HP and performance results, they go out and actually buy too much cylinder head for what they need, and loose at the top and the bottom of the RPM range. Always good to deal with a pro if it's viable or available, CFM is not everything, and actually down on the list of "importance" in a lot of cases.
    GoldenOne7710 and 1980RS like this.
  2. 1980RS
    1980RS Veteran Member
    3,222
    532
    Jun 17, 2006
    MN
    You are right on that. Most people "DO" buy more cyl than they need, that's ok if you plan to build something bigger in the future but as I just found out recently with the BBC PP heads vs. Closed Chamber heads, bigger is not always better. Same goes goes for intakes and headers. Bigger headers most of the time on a mild build make less power and giant single plane intake while can work in some instances usually don't.
    GoldenOne7710 likes this.
  3. G72Zed
    1,080
    235
    Sep 8, 2015
    Yep, big CFM sells heads, always has. I still get caught in that sometimes, hard not too. But, been down that road, flow bench hero's, and comes up short on the pump.
    1980RS likes this.
  4. 1980RS
    3,222
    532
    Jun 17, 2006
    MN
    I will take a smaller port head that flows the same as a larger port and it will kick butt over than big port head. You just have to remember the 375hp 396 they were pigs compared to a 350hp 396. I used to beat up on those big head engines all the time. Right now I have some large port Vortec heads and some 062's that I will port for my new 406 project. Even though the large port heads flow more the 062's ported up to around 6K will kick the large ports butt.
    GoldenOne7710 and G72Zed like this.
  5. muscl car
    21,639
    611
    Jul 8, 2001
    High Desert of Hesperia Calif
    Very Happy with my AFR cyl heads !!!!!
  6. G72Zed
    1,080
    235
    Sep 8, 2015
    Yep, you are correct on that. And makes you wonder why some things work, when they shouldn't have, like taking the 396/375 hp Rectangle port intake and bolting it on the 396/350HP oval port heads, and in other BBC Rec. int to Oval port combo's.
    The 396/375hp did not have the CI or RPM to take advantage of the port's design/layout or CFM's.
    1980RS likes this.
  7. ZEN357
    ZEN357 Veteran Member
    383
    70
    Feb 12, 2018
    I've had really good luck running Edelbrock heads.
    https://www.jegs.com/c/Engines-Comp...964792+900350+4294958194+4294958269&Tab=GROUP
  8. 1980RS
    3,222
    532
    Jun 17, 2006
    MN
    Here is another example, the LS3 head. 265 CC runner on a 364 ci. in. engine, only drag race or nascar people do stuff like that. Put money on it if you stuck a set of AFR 235 CNC ported cathedral port heads on a 5th gen Camaro it would run low to mid 12's easy.
  9. Justin79maro
    Justin79maro Veteran Member
    152
    Jan 15, 2015
    Bonne terre, missouri
    Sorry for such a late response, but no I wouldn’t get them milled
  10. Justin79maro
    152
    Jan 15, 2015
    I’d like to get it to a 7.40-7.50 I’m doing suspension work on it this winter too, try and help with the launch some
