Stupid floor pan question
Discussion in 'Body Restoration' started by bigdav160, Aug 11, 2015.
  1. bigdav160
    bigdav160 Veteran Member
    592
    Jan 11, 2006
    Klein Texas
    What is the conscience on the pan to rocker connection. Do you release the cross brace and tuck the floor flange behind? Or do you trim the floor flange to go around the cross members?
  2. mark wagner
    mark wagner Veteran Member
    2,129
    19
    Jul 31, 1999
    Saylorsburg Pa. USA
    you could do either. I will be doing this soon too, however I will be putting in inner and outer rockers as well so I am going to attach the braces to the floor them put the pan in after the rockers are in place. after that I will verify the shell is square and weld it up
  3. BARNFIND
    BARNFIND Veteran Member Lifetime Gold Member
    334
    11
    Oct 20, 2007
    GPS WENT DEAD...LOST
    Can you buy inner rockers for a 2nd Gen?
  4. volsfan
    volsfan Veteran Member Gold Member
    2,555
    Jan 4, 2008
    daytona beach, fl
    Yes
  5. mark wagner
    2,129
    19
    Jul 31, 1999
    Saylorsburg Pa. USA
    mine are AMD
