Subframe Measurements Needed
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Kamikaze, Dec 26, 2016.
  1. Kamikaze
    5,038
    Aug 4, 2005
    So. Lake Tahoe CA. USA
    Hello Guys and Gals! Hope you all had a great Christmas!
    I am looking at the possibility of getting back into a project of rebuilding a 74 Camaro but it will depend on if the subframe is repairable. I am looking for a good set of subframe measurements to confirm if the control arm mounting points on this are are where they should be. It appears that there may have been a previous repair to one of the upper control arm mounts and I would like to have the reference information to see if it was done correctly or if I will have to cut and re-weld it back into place.
    I have the GM subframe drawing but it only addresses the measurements of the subframe to the unibody. I need to find the one that helps confirm the "squareness" of the subframe itself and the dimensions of the upper and lower control arm mounting points.
    Anyone have a drawing or specs?
    Thanks in advance for your help!
  2. badazz81z28
    16,593
    438
    Las Vegas, NV
    Couldn't you take triangular measurements to see if it's square?
  3. Lowend
    14,958
    439
    Mar 25, 1999
    San Jose, CA, USA
    I know David Pozzi has these
  4. Kamikaze
    5,038
    Aug 4, 2005
    I thought the Pozzi's would but for some reason I didn't think about contacting them to ask...
