SubFrame Torque Specs?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Johnboy9914, Mar 11, 2008.
  1. Johnboy9914
    Johnboy9914 New Member
    17
    Nov 1, 2007
    Crossville, TN
    I've looked and looked (mabey overlooked) but cannot find a torque specification to re-mount the front sub frame on my 81. The car originally came with a 267 V8, now a has a 355. I'm using new factory rubber bushings (it's my wife's daily driver). Also, what is the best way to measure the subframe for accurate alignment (from a point on the body, from the center of the rear hubs or from the yoke on the differential, or all the above?) I just want to ensure it's right. Thanks in advance.
  2. fiscus
    fiscus Veteran Member
    264
    Apr 2, 2007
    montreal, qc
    there are alignment holes at the middle mounts where you put a pin (you can use a bolt) through the frame into the body to line it all up. I don't know the torque but I think its pretty tight, maybe 80lb-ft or something
  3. 67lemanster
    67lemanster Veteran Member Lifetime Gold Member
    12,662
    9
    Oct 20, 2003
    I AM ILK
    the holes are there just like fiscus says. stick some spare round bar stock in there to get them aligned.
    90-100 ft lbs. and recheck them after a 100 miles or so. however i use my impact set on high ;)
  4. 68400BIRD
    68400BIRD Veteran Member
    2,955
    12
    Feb 7, 2006
    GO PACK GO
    90-100 ft lbs. and recheck them after a 100 miles or so. however i use my impact set on high ;)[/QUOTE]
    Is that why your car sits so low:crazy:
  5. 67lemanster
    12,662
    9
    Oct 20, 2003
    I AM ILK
    yeah i squished them. lol lol
  6. John Wright
    14,712
    215
    Aug 9, 2002
    Rustburg, Va
    Son!...I gotta get me one of them impact wrenches like you got that will crush solid aluminum down like that......LOL:bowtie: :p
  7. 79ZED
    79ZED Veteran Member
    3,080
    Jan 31, 2000
    Nanaimo, B.C., Canada
    Radiator support body mounts should be 30-54 lb ft.
    Underbody mounts ( firewall and end of subframe ) should be 100 - 130 lb ft.
    John
  8. Johnboy9914
    17
    Nov 1, 2007
    Crossville, TN
    Thanks to everyone, appeciate the info:cool:
  9. Willy 71SS
    Willy 71SS Veteran Member Lifetime Gold Member
    183
    Mar 3, 2000
    Latrobe, PA US
    90-100 ft-lbs is what I have found too for subrame bushings.
    The alignment pin was .610" +- .002", the 5/8 or 16 mm pin sometimes recomended was to large. I got this # from an assy manual.....
  10. John Wright
    14,712
    215
    Aug 9, 2002
    Rustburg, Va
    I found that a tire iron(bumper jack handle/lug wrench) fit mine the other day and worked great.
