Subs in trunk,should I patch the holes to the backseat?
Discussion in '1978 - 1981 Specific' started by Scamp1978, Dec 3, 2017.
  1. Scamp1978
    Scamp1978 New Member
    Dec 3, 2017
    Hey everyone, I'm planning to put subwoofer in the trunk of my 78 z28, there are large holes that lead into the cab but would be against the backseat, I not sure if it's necessary to weld them shut while the cars apart or if it wouldn't make a difference.
  2. JasonZE
    JasonZE Veteran Member
    516
    Sep 11, 2009
    NewZealand
    i have a 10inch sub and have run a few different set ups, the holes are there and sound is great so I doubt you will gain anything and finding anyone who has done a back to back comparison will be near impossible I would imagine
  3. PalmbchZ28
    PalmbchZ28 Veteran Member Gold Member
    759
    322
    Jan 29, 2017
    West Palm Beach Fl
    I have a 12" in the trunk and it is awesome. I mounted my box to the back of the seat panel using a low profile truck box. The jack just barely fits on its factory mount. IMG_20171125_083806902~3.jpg
  4. Scamp1978
    Dec 3, 2017
    Ok thanks, just making sure.
  5. berg2695
    berg2695 Veteran Member
    242
    44
    Nov 13, 2011
    AUBURN, WA
    You must leave some open space there or the HVAC system won't work properly. Almost all of the ventilation flows into the trunk and out the door pillar vents (unless a window is open of course). Good luck on your project!
    FlaJunkie likes this.
