Survivor 1973 Camaro Type LT RS Z28
Discussion in 'Camaros for Sale' started by bka80s, Nov 9, 2019.
  1. McCune
    McCune Veteran Member
    1,031
    176
    Aug 22, 2015
    st.george utah
    That's a nice car but a survivor?
  2. bka80s
    bka80s New Member
    17
    Nov 6, 2019
    Your post is one of the reasons I put this out for discussion. That’s a good question.
    My thoughts were that it was more of a survivor car than anything else. It’s still in original condition, has not been restored and could easily be taken back to 100% (or close to it) original condition.
    The car actually looks much better in person. The body and original paint are close to perfect.
    What’s the best description for a survivor? Is it always 100% original, untouched? For example, this car still has the original windshield wipers installed.
    How would you describe the car?
    I’m truly asking your opinion. I appreciate the feedback. Thank you.
    1970BCRS likes this.
  3. flht99b
    flht99b Veteran Member
    247
    41
    Nov 28, 2014
    Knoxville, TN
    Mild resto-mod with original paint. If everything is available to put it back to stock and that was done, then it is an original survivor and probably have the highest value.
  4. bka80s
    bka80s New Member
    17
    Nov 6, 2019
    I thought about describing it as a resto-mod, but the car has never been restored, so it seemed like that didn’t quite fit.
  5. McCune
    1,031
    176
    Aug 22, 2015
    st.george utah
    Trim Tag has been removed from car and installed with the incorrect rivets, Cowl is painted the wrong color. I think this car has been changed more than you think. That said it is a very nice car.
  6. McCune
    1,031
    176
    Aug 22, 2015
    st.george utah
    No body color paint on the cowl ever. Your car has incorrect pop rivets and the screws did not get used until sometime in April 73.
  7. bka80s
    bka80s New Member
    17
    Nov 6, 2019
    Thanks. I just went back and looked at some high res photos of the data plate and you can see black paint under the tag and black paint residue in the lower creases of the tag itself.
    Thanks for the info. I questioned that cowl also.
  8. McCune
    1,031
    176
    Aug 22, 2015
    st.george utah
    The trim tag will have the red oxide under it, the tag was installed before the black paint and before body color.
  9. bka80s
    bka80s New Member
    17
    Nov 6, 2019
    Appreciate the info coming in. I want to be sure the car is described as precisely as possible.
    All things considered, I believe this is a excellent example of an LT with RS and Z28 options that will make it desirable. She has a lot of positives, and could be brought back to near stock.
    She does run and sound incredible with that ZZ572 in her though.
  10. McCune
    1,031
    176
    Aug 22, 2015
    st.george utah
    It is a great car, would be nice to verify it has the matching hidden vin numbers on the firewall behind the heater motor but that is some work to expose it. I always question a car that has had the Trim Tag removed.
