Sway bar hitting my 9" rear end help
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by alpinemetal, Mar 23, 2020.
  1. Lowend
    15,145
    545
    Mar 25, 1999
    San Jose, CA, USA
    Yep -
    That's the solid front eye spring I warn folks about.
    Fair warning, you should probably plan to run some rather stiff (~800 lbs/inch) springs upfront to help compensate
  2. alpinemetal
    alpinemetal Member
    66
    Jul 5, 2014
    San Diego, CA
    Thanks, without a doubt this is the best F body forum
  3. alpinemetal
    alpinemetal Member
    66
    Jul 5, 2014
    San Diego, CA
    I'm running a 496 with aluminum heads and intake and probably a reinforced bolt on fiberglass hood, the springs a Detroit Speed small block per their tech with overload shocks and C5 brakes.
  4. Lowend
    15,145
    545
    Mar 25, 1999
    San Jose, CA, USA
    I'm assuming you mean Coilover shocks. Assuming they are standard DSE off-the-shelf they have a spring rate of 575 lbs/inch
    Soft for this if you ask me.
    The good news that coil over style springs are generally relatively easy to change. If you already have them, try running them. I think you will probably end up going stiffer, but try what you have first.
  5. alpinemetal
    alpinemetal Member
    66
    Jul 5, 2014
    San Diego, CA
    Coil over shocks
  6. alpinemetal
    alpinemetal Member
    66
    Jul 5, 2014
    San Diego, CA
    I meant load carrier shocks with SBC 2" lowering springs
  7. Lowend
    15,145
    545
    Mar 25, 1999
    San Jose, CA, USA
    I don’t know what load carrier shocks are
  8. alpinemetal
    alpinemetal Member
    66
    Jul 5, 2014
    San Diego, CA
  9. alpinemetal
    alpinemetal Member
    66
    Jul 5, 2014
    San Diego, CA
  10. dave@ztech
    3,617
    761
    Mar 27, 2016
    NY
    I don't think you would like the ride, however, I ran air shocks on my first 70 Z for years to get the right ass in the air look, HAA HA ,
